20 Most Recent
Linksys By Cisco E2500 DualBand WirelessN Router Questions & Answers
How can I remove my neighbor from my network
Easiest thing to do, Change the password to your router. Once this is done, it will prevent your neighbor from any further access to your router and of course prevent internet access. Most all routers are simply a local web address for access. Example: 192.168.1.1 typed inside a browser address pane will take you inside the router. Check your router for setup procedures.
Have a great night.. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/william_02fc2766c1e13b73
Forgot guest pw on cisco e2500
If a password was set by user, no one else will know it if you forget it.
If the password needs to be reset to factory, so you can log in with the "default" password AND RE-SETUP EVERYTHING, then you'll need to reset the Linksys E2500 to factory defaults. You can usually do that via a special button or sequence of actions.
The E2500 manual will have specific directions for performing a factory default reset. You can download the manual for the E2500 from
http://support.linksys.com/en-us/support/routers/E2500
I have a linksys E2500 and I need the password
You could try to connect to your router with a CAT5e network cable. Then open your browser and open the webpage http://192.168.1.1
When prompted for your username and password, try password 'admin' (without quote marks) and leave username empty.
If that doesn't work, reset your router and configure all the options over again (make sure you have all required information for the settings). For more information, look at this knowledge base article: kb.linksys.com/Linksys/GetArticle.aspx?docid=6af0fc7147664d2eaef47a2189a1ffce_E2500_FAQs.xml
What do I do if I forgot my password?
Well, if you forgot your password, you will need to completely reset the device to factory settings. There should be a recessed button on the back that is only accessible with a pin or paperclip. Press that and it will reset all of the settings to default.
Lynskys e2500 router dropping log me in
Check the quality of your internet, you can try continous ping command on a ip e.g:
open run: type cmd and hit enter
type: ping google.com -t
it should give reply....
check how many timed outs, that means droped packets,
could be internet issue,
If not check that you are not moving to far away from router range.
Forgot guest password
In that case you have to rest the router. There two ways to do so:Method:There is a small button at the back of the router labelled as reset. Its very narrow you need to press and hold it for about 10 - 20 sec using a needle or any sharp object.Method 2: If you are not able to find the button. You can use a we-based portal to do so. Connect your computer to the router and enter the IP mentioned at the bottom of the router in your internet browser. User name and password will be provided at the bottom of the router somewhere next to the IP address. Once you log in you can reset the router from there.
How do I connect router to computer?
Your router must be having port to connect it to computer - it may be either USB, or Ethernet port. use the cables respectively and connect it to your computer, on the same port which you use from router.
Can't remember my paassword
You will need to hold the reset button down and reset the unit to the factory defaults.
Utilize a pen or paperclip to press in the reset button and hold it for 10 seconds (some older units will take up to 30 seconds to reset). This is with the power turned on. You will see all of the lights flash when the unit resets. Give the unit another 2-3 minutes to restart. It will have the factory defaults at that point. Point you browser to http://192.168.1.1 and re-setup the router. The default password should be 'admin' with no username. Hope this helps!
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
