20 Most Recent
Symbol CS1504 Handheld Barcode Scanner Questions & Answers
How to find the com port for the USB driver
You have to look in the device manager. Usually you can get there by right clicking on My Computer then selecting Properties then the Hardware tab and Device Manager. If the CS1504 pulled a virtual COM port it will be listed under Ports (COM & LPT) as Prolific USB to Serial Comm Port with the port named at the end of the line.
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port?
You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC.
If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
My Kenwood 1 ton inverter ac outer not starting some times start show compressor symbol and then turn off and not start again doesn't show any error please guide
If your Kenwood 1 ton inverter AC is having trouble starting and sometimes shows the compressor symbol before turning off, there may be a few things you can check to diagnose the issue.
- Power Supply: Check that the AC is receiving proper power supply, and the circuit breaker is not tripped. Sometimes, due to voltage fluctuation, the compressor may not start.
- Dirty Air Filters: Check the air filters and clean them if they are dirty. Dirty air filters can reduce the airflow and cause the AC to malfunction.
- Faulty Thermostat: If the thermostat is faulty, it may not be able to detect the temperature properly and cause the compressor to not start. You can check this by setting the temperature to a lower level and see if the AC starts.
- Low Refrigerant Level: Check the refrigerant level in the AC. Low refrigerant levels can cause the compressor to not start.
If none of these steps solve the issue, it may be best to contact a professional AC technician to diagnose and repair the issue.
How to type degree symbol on mac
There are a few different ways to type the degree
- Use the keyboard shortcut: Press and hold the Option key, then press the letter K on your keyboard. This will insert the degree symbol.
- Use the character viewer:
- Go to the Edit menu and select Emoji & Symbols.
- In the search field, type "degree".
- Double-click the degree symbol to insert it into your document.
- Use the ASCII code:
- Press and hold the Option key and the Shift key.
- Press the number 8 on the numeric keypad. This will insert the degree symbol.
I hope this helps! Let me know if you have any other questions.
Videocon ac remote not working
Please reach out to videocon on twitter to help take care of this issue: @VideoconIndia . You can tweet their handle with the issue included.
You can also call 1800 1370 444 to reach them. I believe that is a number based in India. Thank you.
