20 Most Recent
Toshiba Satellite Pro 6000 and 6100 14.1 LCD Display LQ141X1LH53 (P000316660) CD-ROM Drive Questions & Answers
It's asking me for a
You check this website out:
http://www.laptop-repair.info/toshiba_bios_password.html
But if that doesn't help you need to send the laptop to Toshiba to get it fixed.
8/27/2011 1:46:46 AM •
Toshiba...
Answered
on Aug 27, 2011
My Toshiba Satellite Pro, when I turn my laptop
The first question is - did you create a password recovery disk? If not you will have to re-install the operating system.
Your BIOS default will be set to start up from teh DVD drvie - insert the recovery disk and it will re-install the operating system.
12/18/2010 8:58:15 PM •
Toshiba...
Answered
on Dec 18, 2010
My computer says wen i turn it on enter built-in
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
9/18/2010 4:07:09 PM •
Toshiba...
Answered
on Sep 18, 2010
If i reformat my hard drive will that get past the
You will have to run Fdisk then Format then partition the drive in order to remove the password. if it is ran threw Bios you will have to remove the bios battery and unplug the power supply for 5 minutes to erase it from bios. Hope this helps.
2/17/2010 2:01:07 PM •
Toshiba...
Answered
on Feb 17, 2010
HDD password
It’s called ‘platter-locked’ and it cannot be easily bypassed or unlocked (the password is built into the hard drive).
If you do not need any information on the hard drive I would suggest buying a new 2.5” hard drive for laptops and install a new one (it will be cheaper).
If you would like to read more about this:
http://www.hardwareanalysis.com/content/topic/34045/?o=0
1/18/2010 7:02:20 AM •
Toshiba...
Answered
on Jan 18, 2010
My Toshia Satellite Pro 6100 Screen Cant select 1024x768
a little clarification... did you reformat your laptop? if your answer is yes>>> maybe some driver of your laptop are not loaded>>> to check the loaded just go to >>> my computer>> r-click then click manage>>> then click device manager>>> if you see color yellow sclamation point or question mark>>. it meaning to say some of your driver not installed>>> so you must download the compatible driver for your laptop>>> you can download driver on this site>>>
www.driverguide.com....!
12/29/2009 1:23:25 PM •
Toshiba...
Answered
on Dec 29, 2009
Computer requesting Hdd Password on start up
You are getting windows login user password. You need to remove password from user account.
follow link: http://pcsupport.about.com/od/tipstricks/ht/delxppassword.htm
Thank you
Sachidanand
8/17/2009 10:01:34 PM •
Toshiba...
Answered
on Aug 17, 2009
The problem seems to be that if I move my Toshiba
What you have said is very likely a hardware issue instead of being related to the registry cleaning.
Is the laptop covered by warranty?
It seems like a problem on the video adapter, its most likely failing or a cable is loose.
7/30/2009 7:31:12 PM •
Toshiba...
Answered
on Jul 30, 2009
Blue Vertical Line on my laptop screen
Does the line still appear if you plug it into an external monitor? If not sounds like your laptop screen has developed a fault, unlikely to be related to what you did with your camera just coincidence. The only way around this would be to replace the laptop screen. Not an easy job but not too difficult if you can find the same screen for sale on Ebay for example. Either that or replace the laptop and sell the old one on ebay for someone else to fix.
Hope that helps
Chris
7/26/2009 2:26:24 PM •
Toshiba...
Answered
on Jul 26, 2009
Hi, i have lenovo laptop
Hi, depends on the laptop in question. If it's a newer model I am afraid your pretty well knackered as the the hard drive will be encrypted using the security chip in the laptop and one won't work without the other so I don't think a new hard drive will work either unfortunately but it might do. If this is the case you have 4 options
1 - Re-solder a new security chip onto the board (good luck with that).
2 - Replace the motherboard (expensive unless you can pick one up on Ebay).
3 - Try a new hard drive (might be lucky)
4 - Remember the password
You could also search Google for a hack, As I said depend on the age of the laptop but are some for older chips but not for the newer ones as far as I know. I have been successful with older HP's and Toshiba's but I haven't had to break into one for a while and as I said last time I tried with a lenovo I spoke to lenovo and they told me it wasn't possible.
Hope that helps
Chris
7/26/2009 2:20:32 PM •
Toshiba...
Answered
on Jul 26, 2009
Does the Toshiba Satellite Pro 6000 have a
The Toshiba Satellite pro 6000 doesn't have a built in microphone as far as I can remember but it does have a microphone socket at the front next to the headphone socket. Both sockets are on the bottom left hand side left if looking from the front. The microphone one is the one on the left, if you look closely there are symbols next to each of the sockets, one looks like headphones the other like a microphone.
Hope that helps
Chris
7/26/2009 2:10:57 PM •
Toshiba...
Answered
on Jul 26, 2009
Hdd password
What is HDD Password?
All hard disk drives have the possibility to set a hardware password,
thus making the drive completely inaccessible unless a correct
password is provided during the BIOS POST test. When you set a password
on your notebook, the drive becomes locked as well. XBox gaming consoles and some
desktop computers can also lock hard disk drives. This is usually called
"HDD password" or "ATA password".
If you forget the original HDD password, there is no way of restoring it
by generic system tools. HDD Unlock Wizard incorporates proprietary
unlocking algorithms which allow to remove an unknown HDD password and make
hard drive usable again.
I have a software enable to reset the password security on your harddriver but you need to pay my professional charge. If sound interested please email
[email protected].
Please rate me solved if you like my solution.
Best regards,
Philip
10/4/2008 12:17:20 AM •
Toshiba...
Answered
on Oct 04, 2008
My Toshiba Laptop won't turn on
my laptop is having trouble booting up. I get the black screen that says that Windows did not start Successfully. I can't get past this screen. What can i do?
6/25/2008 5:11:53 PM •
Toshiba...
Answered
on Jun 25, 2008
Satellite pro boots up sometimes
connection problem from power board to mainboard connector..try jumpering with a thin wire,or magnetic wire..as a replacement to a deffective connector,,I already try it,,and work fine until now..
4/8/2008 9:20:58 AM •
Toshiba...
Answered
on Apr 08, 2008
Toshiba Satellite Pro sp6000 CDRom
You can try this website for the driver search application, i use it every day for the repair of computers, Hope it is of help to you,
http://www.softpedia.com/get/System/System-Miscellaneous/DriverMAGIC.shtml
3/26/2008 10:07:14 AM •
Toshiba...
Answered
on Mar 26, 2008
