20 Most Recent Zyxel Communications NBG416N 11N 150N Wlan Router 5DBI Antenna Wireless Questions & Answers
2answers
Disable ap/client isolation to allow chromecast to work
You need to login to the routers web interface and the settings will be in the advance WiFi section, probably a tick box. A typical web interface can be found at the following address in your browser http://192.168.1.1/ Username usually admin and password could be password or blank or 1234 or admin. Check with manual.
3/29/2022 8:19:58 PM • Zyxel... • Answered on Mar 29, 2022
How to set up zyxel NBG416N in universal repeater mode
Yes Zyxel nbg-416n does indeed support repeater mode but you need to make sure you have at least firmware version v1.00(USA.5)C0 and you can switch to that mode via maintenance/sys op mode.
2/11/2018 5:12:09 AM • Zyxel... • Answered on Feb 11, 2018
Zyxel NBG-416N netflix slow
7/15/2016 12:08:27 PM • Zyxel... • Answered on Jul 15, 2016
Why can't it get out to internet
computer? did you run setup and install drivers? do you have an internet provider?
8/3/2014 11:41:32 PM • Zyxel... • Answered on Aug 03, 2014
0answers
0answers
I have gone through the
Open a command prompt (start button, type cmd and press enter)Type ipconfig and press enter, scroll up to the top of the output and check your IPv4 address in the form ***.***.***.*** It should start 192.168.x.x. If you get something that starts with 169.x.x.x then your wireless router is having trouble with DHCP. Power down your router and modem for 30seconds then plug in the router and wait 30 seconds then the modem.
11/6/2011 8:19:26 PM • Zyxel... • Answered on Nov 06, 2011
Do i need to set up zyxel for wpa-psk
You don't have to; however doing so will prevent other unauthorized people from getting on your network. People on your network can steal your bandwidth (slow down your internet speeds) and even potentially get on to any computer on your network.With WPA private shared key (PSK) you will only need to enter the password once per device you choose to connect to the network. Make sure you select WPA2 and not WPA if you have it available. The first standard WPA is still pretty easily broken as is WEP.
11/6/2011 8:03:23 PM • Zyxel... • Answered on Nov 06, 2011
My compaq presario v2000 laptop cannot detect the
I would guess that all the other wireless routers are broadcasting using the G wireless standard 802.11g and your router is only broadcasting using the newer N 802.11n standard. Your laptop only supports B/G. Check your settings on your router and either change it to G or dual G/N mode so your older laptop can find the network
11/6/2011 8:00:04 PM • Zyxel... • Answered on Nov 06, 2011
I have a Zyzel nbg416n
Wireless routers do what is called signal shifting. This means as the signal gets weaker (either because of distance or because it has to pass through walls, strong electrical fields etc) the speed is automatically dropped to as low as 6mbps. All the obstacles will kill your signal very quickly as well. You can try moving your router to a better location or invest in a repeater to place between your wireless router and the computer.
11/6/2011 7:56:34 PM • Zyxel... • Answered on Nov 06, 2011
I have the Zyxel ngg-416n
Not really familiar with MAC but make sure you're plugging the ethernet cable into a lan port on the router and not the WAN/uplink port.Also check to see if your lan connection isn't disabled on the computer.For starters
11/6/2011 7:51:50 PM • Zyxel... • Answered on Nov 06, 2011
I need step by step
Can't get any easier than following the user guide.ftp://ftp2.zyxel.com/NBG-416N/user_guide/NBG-416N_1_Ed1.pdfAssuming your modem is on an plugged in.
  1. Plug an ethernet cable from the modem to the router's WAN / Uplink port
  2. Plug the power cable into the router
  3. Plug another ethernet cable from one of the LAN ports (1-4) to an ethernet port on the computer your going to use to setup the router.
  4. Open a web browser and enter 192.168.1.1 and press enter
  5. When prompted for a login use USER: admin PASS: 1234, press enter
  6. Now follow from page 35 of the guide listed above.
At the least change the SSID (the name of your network broadcasted)The password to login to the routerEnabled WPA2 PSK for your wireless security this will keep 99% of people off your networkComment if you have further questions
10/15/2011 11:56:22 PM • Zyxel... • Answered on Oct 15, 2011
Just got comcast cable internet
The router should work out-of-box.Ensure that you have an ethernet cable from your modem to the WAN/uplink port on your router.I would also call comcast and verify they have the correct MAC address for your modem. If they don't your service will not work period.Comment back for further assistance
10/15/2011 11:48:51 PM • Zyxel... • Answered on Oct 15, 2011
It will connect but Cannot
Here is a link to the user guide for your modelftp://ftp2.zyxel.com/NBG-416N/user_guide/NBG-416N_1_Ed1.pdfLocated on the first page is the defaultsAddress: 192.168.1.1user: adminpassword: 1234If this still is not working I would recommend locating the reset button and holding it in for 15 seconds this will erase any previous config and restore the default above.Comment back if you need further assistance
10/15/2011 11:46:27 PM • Zyxel... • Answered on Oct 15, 2011
2answers
How do I reset NBG-416N
Locate the reset button on the back of the router. It will either be a small button or pin hole. For the pin hole use a paper clip and press the button for 10 seconds.
Comment if you need more help.
9/14/2011 1:12:02 AM • Zyxel... • Answered on Sep 14, 2011
Ngb416n using wpa2 psk security.
Some wireless adaptors may encounter the compatibility problem with some routers when adaptor's driver is out dated. I have a Toshiba laptop that had the same problem. After I installed the latest driver, the problem resolved. You may need to contact manufacturer of the computer to get the updated driver. If you cannot get a driver updated, you can also try to lower the security to WEP.
9/2/2011 6:19:13 PM • Zyxel... • Answered on Sep 02, 2011
Can I use a Zyxel VMG3625-T20A router as a range extender?
Question edited for correct name of maker, add a few capitals. Question moved to Zyxel Router. There is some advice here. https://forums.techguy.org/threads/solved-how-do-i-bridge-my-router.1144390/ https://www.google.com/search?q=use+a+Zyxel+VMG3625-T20A+router+as+a+range+extender ..
3/31/2022 9:08:13 PM • Zyxel Computers... • Answered on Mar 31, 2022
I cannot log into my ZYXEL VMG3625-T20A router admin panel after changing access password
google router and forgot password or locked out
1/7/2020 4:26:12 PM • Zyxel Computers... • Answered on Jan 07, 2020
3answers
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next? Login to Your ZyXEL Router Using the Router Password Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: =============== Forgot Router Password? If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings. What should you do? Login to Your Router Using the Default Router Password Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides. Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!) Find Your Default Router Password Simply select your router manufacturer from the list below to display the default router passwords and usernames.
8/3/2019 7:47:05 AM • Zyxel Computers... • Answered on Aug 03, 2019
Zyxel Communications NBG416N 11N 150N Wlan Router 5DBI Antenna Wireless Logo
Popular Tags
20 questions posted
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Zyxel Computers & Internet
Most Popular Question
ngb416n using wpa2 psk security
  • Computers & Internet
