20 Most Recent
Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display- LP150X06 CD-ROM Drive Questions & Answers
My Toshiba Satellite A30 is
blue screen can be fixed by boot repair, but hot fan is heat overload fffroom cpu and gpu not wworth motherboard reppair,replace computtter
12/3/2018 3:16:38 PM •
Toshiba...
Answered
on Dec 03, 2018
My toshiba satellite a105-S4234 laptop says it does not have an audio device but no yellow marks through the device manager sound and audio files. Help
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
2/15/2012 11:16:18 PM •
Toshiba...
Answered
on Feb 15, 2012
Disk drive does not work. Possibly need a driver.
I would go into the BIOS and make sure that the correct drive and drive type is there. Up on the boot sequence, hit F2 and go into the BIOS.
Also, go to the toshiba website download the drivers you need. I do it all the time.
1/18/2011 9:53:01 PM •
Toshiba...
Answered
on Jan 18, 2011
My Toshiba Satellite A30 laptop keeps switching off when charging
I would suggest that you try it with another AC adapter first, because it seems the adapter is faulty and therefore supplying more current into the laptop than necessary.
If it works perfectly with another AC Adapter, then you might just have to change your AC Adapter.
Hope it helps.
7/13/2009 10:34:20 PM •
Toshiba...
Answered
on Jul 13, 2009
NO Wireless on Toshiba Satellite
attach your wireless router with modem then turn on the pc .. there is a pin whole at back of wireless router pin it in it would reset all of your setting . than go to internet explorer address bar type the IP 192.168.1.1 ususaly and the passward would be admin as well as user name .. then set the setting according to your requirment with out opposing IP ..than first turn of every thing computer modem router
then after 20 min first switch on the wireless router then modem and then your computer .. you will get connected through wireless router..
6/25/2009 1:44:59 PM •
Toshiba...
Answered
on Jun 25, 2009
