20 Most Recent
Toshiba Satellite Pro 6000 Notebook Questions & Answers
I have Toshiba satellite C850-x0010, Suddenly
Should be able to have it replaced assuming it has failed; May need to order the part from Toshiba, but otherwise you can replace it yourself as the sensor should be modular in that it can be replaced; If you are not to tech savvy may want to bring this into a local PC repair shop.
12/10/2013 4:23:39 PM •
Toshiba...
Answered
on Dec 10, 2013
Toshiba sp6000
you need to go into the drivers and click enable or if it has not been reinstalled u need to install it manually yourself
7/16/2012 1:34:34 PM •
Toshiba...
Answered
on Jul 16, 2012
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
7/13/2012 9:32:19 PM •
Toshiba...
Answered
on Jul 13, 2012
I want to reset my
BIOS passwords in modern portables require a master password to bypass/reset if the original password is lost forgotten. You will need to contact Toshiba Tech Support and if the system is not under current warranty that will probably require payment to resolve.
6/25/2011 12:21:56 PM •
Toshiba...
Answered
on Jun 25, 2011
I have a Toshiba Satellite
The internal wireless cards of these laptops are underneath the keyboard (remove the plastic strip above the keyboard, then 2 screws holding down the keyboard, then remove the Torx security screw holding the WiFi cover). See if the snow job might have gotten to it and perhaps corroded it? The stock WiFi card is an Agere MPC-13a/20 (MPC-13a/20R) model - widely available on eBay for $10 or less.
If it's too troublesome, a wireless card that plugs into your PC card slot is probably the cheapest solution.
3/5/2011 4:11:23 AM •
Toshiba...
Answered
on Mar 05, 2011
Can i upgrade the memory?
Go to crucial.com and run a memory scan.It will show you What the max memory is for each slot.RICHARDM69
9/10/2010 2:28:25 PM •
Toshiba...
Answered
on Sep 10, 2010
About every 4th time I start up my new Toshiba
Update all your windows drivers, update anti virus and run. Also I would suggest you download malware bytes anti malware which is a free software and run it. Sometimes trojans and or viruses could cause this problem.So to summarize, update drivers, run full anti virus scan, run malware bytes too. Hope this helps, any question please feel free to ask.Good luck.
7/20/2010 3:13:20 PM •
Toshiba...
Answered
on Jul 20, 2010
Toshiba sp6000 512mb sdr 133mhz chips
These are the memory modules for your notebook, any others won't work. The max is 1024mb
You need these modules:
PC133 512MB (PA3108U-1M51)
PC133 256MB (PA3086U-1M25)
PC133 128MB (PA3085U-1M12)
If the modules you've installed meet the above criteria then make sure they are seated correctly.
Bear in mind it is always possible one of the modules is defective so try them one at a time, also they are non-eec.
7/8/2010 6:10:36 PM •
Toshiba...
Answered
on Jul 08, 2010
Ghost failed
Find someone that has the Windows disk that matches your windows sticker. Install it and use your number. Then rebuild from there getting any drivers you need from the Toshiba website.
1/19/2010 11:53:34 AM •
Toshiba...
Answered
on Jan 19, 2010
