20 Most Recent
Toshiba Satellite 1805-S253 Notebook Questions & Answers
How to run setup
Hi
While holding the ESC key, turn the power on.
Do not release this key until a message appears.
Press F1 to enter the System Setup utility
Good Luck
10/30/2011 2:11:41 PM •
Toshiba...
Answered
on Oct 30, 2011
I have a Toshiba satellite
It sounds as though your system is getting no power at all- try a second ac adapter. If that does not work, if in warranty, contact your technical support provider to get it serviced. If not, there is a good chance you will need a replacement motherboard- find a reputable technician and see about purchasing the replacement board. I’m happy to help further over the phone at
https://www.6ya.com/expert/susan_42b401e0b1603d8a
10/12/2010 10:58:11 AM •
Toshiba...
Answered
on Oct 12, 2010
Satellite 1805-S253 PC Notebook: MY D DRIVE IS READING BUT STOPS. AND SAYS MY FILE ...
Hi, "first," restart the computer, and click on the "Start Button," in the (right pane) select to open the Computer. Check to see if there's a DVD RW Drive (D:) in the "Device: with (Removable Storage) area." If the area is (Blank)? Go to and select All Programs, scroll to find the Media Disk Player. You may need to Setup / Install the player, and "Update the Drivers," when the (install is completed) follow all the instructions. "Remember to always click on the Apply and OK buttons after making the changes, and lastly, restart the computer." "If the problem still exist, try going to the "Device Manager" from the Control Panel, [Roll-back, and or Update Drivers], restart the computer. Next, in a final attempt to fix the problem go back to the (Control Panel), and select from the "Update Options' "Let me Choose... To update the drivers Manually" this will in stall the "original" (Drivers) that came with the computer. "Rating the solution for its helpfulness is appreciated, thanks."
5/16/2010 4:07:33 PM •
Toshiba...
Answered
on May 16, 2010
This is a sign of a driver that really got corrupted , one thing that you can do here is to format and recover the files after doing the format and hopefully those files inside the drive are still intact and not fully damage or corrupted. So format the drive and once done download this software for recovering the files from the formatted drive its called Recuva you can download it from download.com and its for free. Install it to your computer and when you're already trying to recover the files enable the deep scan option.
3/26/2010 4:06:44 AM •
Toshiba...
Answered
on Mar 26, 2010
Is there a backdoor bios
The Backdoor passwords are not determined by the laptop manufacturer - the backdoor passwords depend on the manufacturer of the bios itself. Is it an Award biosor an AMI bios etc?
Award BIOS backdoor passwords:
ALFAROME
BIOSTAR
KDD
ZAAADA
ALLy
CONCAT
Lkwpeter
ZBAAACA
aLLy
CONDO
LKWPETER
ZJAAADC
aLLY
Condo
PINT
01322222
ALLY
d8on
pint
589589
aPAf
djonet
SER
589721
_award
HLT
SKY_FOX
595595
AWARD_SW
J64
SYXZ
598598
AWARD?SW
J256
syxz
AWARD SW
J262
shift + syxz
AWARD PW
j332
TTPTHA
AWKWARD
j322
awkward
AMI BIOS Backdoor Passwords:
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
CONDO
Phoenix BIOS Backdoor Passwords:
phoenix
PHOENIX
CMOS
BIOS
Misc. Common Passwords
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
Other BIOS Passwords by Manufacturer
Manufacturer
Password
VOBIS & IBM
merlin
Dell
Dell
Biostar
Biostar
Compaq
Compaq
Enox
xo11nE
Epox
central
Freetech
Posterie
IWill
iwill
Jetway
spooml
Packard Bell
bell9
QDI
QDI
Siemens
SKY_FOX
TMC
BIGO
Toshiba
Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
11/5/2009 2:33:09 PM •
Toshiba...
Answered
on Nov 05, 2009
Do not know video or audio cards.
Probably a Trident video card. Go into Control Panel>System and select the display adaptor right click and select update driver don't let it contact windows update. Thwe next step should then say this wizard helps you install software for and it will tell you the hardware. Repeat for the audio card.
If that doesn't work right click on the adaptor>Properties>Details>Hardware IDs and google the ven and dev data
10/10/2009 5:45:55 AM •
Toshiba...
Answered
on Oct 10, 2009
Bios
for bios password reset u need to plug out the bios cell which is present below ur laptop battery...& then plug it again...
6/17/2009 3:15:17 AM •
Toshiba...
Answered
on Jun 17, 2009
Toshiba 1805 will not start up
The RAM may need reseating or it maybe faulty.
If reseating the RAM module/s doesn't work and if you have two RAM modules, then try one at a time.
You could take the RAM to your friendly shop and get them tested or test them in another laptop.
6/1/2009 1:05:43 AM •
Toshiba...
Answered
on Jun 01, 2009
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
3/14/2009 3:10:21 PM •
Toshiba...
Answered
on Mar 14, 2009
There is only a phone
the one that connects to your dsl should be Ethernet. Are you sure there is no network port on your PC? the image below shows where this port is. does the dsl fit in here?
2/3/2009 3:15:56 PM •
Toshiba...
Answered
on Feb 03, 2009
BIOS password
Not sure if you are up to this but if you remove the bios battery for a minute it will reset you may also be able to search for manual for laptop or you may have one
1/23/2009 3:26:58 AM •
Toshiba...
Answered
on Jan 23, 2009
Laptop problem
oooh..blue screen too, I'll bet..you may need to boot from install cd, to recover, if you don't have a recovery disk..that is..
1/23/2009 2:19:42 AM •
Toshiba...
Answered
on Jan 23, 2009
