20 Most Recent
Toshiba Satellite 1005-S157 Notebook Questions & Answers
I have a Satellite 1005
If you are talking about wireless networking, all I did was buy a wireless PCMCIA card and install the drivers on the CD or buy a usb network adapter and do the same. I am still running Windows XP Home on my system and with bringing the ram up to 512 MB which is the maximum, it still does what I need it to do.
2/13/2015 7:32:42 AM •
Toshiba...
Answered
on Feb 13, 2015
Touchpad needs to be turned off
Down by the clock, there should be an icon for the touch pad. Right click and disable.You will need to have a mouse attached as disabling the touch pad disables *all* parts of it, including the touch buttons down there.If you no longer have the icon for the touchpad down by your clock, there should be an icon for it in Control Panel, OR you go to Mouse in the control panel, and one of the tabs in the mouse control applet will have an option to check or remove the check from, for using the touch pad.If the issue is that it still senses your hands when typing .. you might be able to decrease the sensitivity, and there are apps you can buy (inexpensive and some may be free if supported by the manufacturer or by the touch pad maker) apps that will also disable the touch pad while you are typing, and that re-enable after you stop typing for X seconds. etc..
7/28/2012 2:30:17 PM •
Toshiba...
Answered
on Jul 28, 2012
Toashiba 1005-S157 won't turn on.
remove the batteries for 2-3minuty, check if it works,
Enter the BIOS, set the boot order of devices on the 1-HDD, 2-CDROM
9/14/2011 10:00:02 PM •
Toshiba...
Answered
on Sep 14, 2011
How do i remove the hard drive from s157
Go
here, click on the tab that says "detailed specs" it will prompt you to save the PDF, open the pdf and on the last page you'll see a picture of where the hard drive is.
It's just two screws, unscrew them and slide it out.
Hope this helps!
10/10/2010 3:05:28 AM •
Toshiba...
Answered
on Oct 10, 2010
I lost the administrator password
Just boot from the recovery disk and reinstall. If you have files that you must keep then before reinstalling boot normally and copy them on a memory stick.
10/8/2010 1:31:05 PM •
Toshiba...
Answered
on Oct 08, 2010
I used the Windows XP recovery disk for my desk
go to start/all programs/accessories/systems tools / system restore and restore to an earlier date.........go back 2 months at least (when your laptop was working fine) ....the system will shut down & reboot up and prompt you with are sure this okay to do click ok.........
7/24/2010 3:54:20 AM •
Toshiba...
Answered
on Jul 24, 2010
Bad motherboard battery
revome by using screwdriver....relase all screw...do not push with magnet screwdriver,it makes trouble at ur board tomorrow
1/15/2010 6:06:47 AM •
Toshiba...
Answered
on Jan 15, 2010
Toshiba Satellite 1005-S157 shuts down
you need to check a few things... when the fan/heatsink assembly were replaced, did you make sure that the thermal pads on the CPU and GPU are NEW/Good.... Make sure that the Heatsink GPU pad Firmly sits in the chip....
You can test the thermal controller by using a hair dryer or heat gun.... Point it onto the heatsink pipes and see if your fan spins when the pipes get hot, then remove and see if the fans slow after a minute...
You might have faulty RAM or Misseated RAM... Pull The RAM chips and reseat them...
Also Make Sure Your CPU Is Locked Down....
Periodic Shut Downs Can Be Caused By Quite A Few Different Things...
Typically it's due to Thermal Damage
Though Failing RAM or A Failing Hard Drive, Overheated Video/GPU Chip, Or Even Failing CPU can as Well Cause This Issue...
11/16/2009 8:02:27 PM •
Toshiba...
Answered
on Nov 16, 2009
Where is ram memory ?
Ram memory is on the underside behide a small opening requiring you to remove 2 screws. You remove the door and they are laying under that.
8/8/2009 7:03:08 PM •
Toshiba...
Answered
on Aug 08, 2009
