20 Most Recent
Toshiba Qosmio G15-AV501/R Notebook Questions & Answers
The fan on my Qusmio
Make sure you don't have any bloat/malware hiding in your processes, this can cause the CPU to reach higher usage and the fan to run constantly.
Open Task Manger (Crtl+Alt+Del on most Windows Versions) and go to the processes tab and see what is running. If theres something that is running that you never started (ex toolbars) and 'kill' the process.
Side Note:
internet explorer seems to like to stick around after you close it.
I was given a qosmio G15-AV501, but it appears to
No particular problem with your unit. In your case it appears that the fan isn't operational - open the laptop and replace it.
Also check in the BIOS the shutdown temperatures, they might be set way too low.
Nothing comes up on the screen when i turn the
Try pressing Fn + F2 key after turning the computer on. Try to perform power drain. Taka out the battery and unplug the adapter. Presss and hold the power button for 30secs. Put the battery back in and plug in your power adapter then turn on the computer.
Let me know if you will still be getting the same issue.
Toshiba G15 laptop has green lines and will not
reboot in Safe Made by pressing F8 at boot up. Then restore the system to an earlier date. This may be happening due to some malicious prog that you have installed or due to a virus. If due to a virus, the install AVG Anti Virus free from www. download.com.
When laptop says no bootable device
It means that you do not have a hard drive that can be booted to start the OS, or that your had drive is defective, or the boot sector of the hard drive is missing or corrupted.
Wireless capability turned on
You just got wireless turned on ?
Does this mean you just added a wireless router to your existing wired network ?
You may need to turn off the DCHP server in the wireless Router and give it a unique ip address eg if wired router is 192.168.0.1 then make wireless router 192.168.0.2 with gateway ip set as 192.168.0.1 then make wired dhcp router not lease out 192.168.0.1 - 192.168.0.20 make subnet mask the same also for each router.
Beep codes
Did you solve the problem? I have the same here, in Brazil.
