20 Most Recent EliteGroup ECS H61H2M2 Intel H61 Sandy Bridge Motherboard Questions & Answers
Why do date and time keep setting to default?
Are you sure you replaced the CMOS battery with a fresh one? Did you install it backwards (the plus side should be UP). I've only seen a bad CMOS battery cause that problem. I would try one you know is new and check the installation. Good luck.
9/2/2015 7:04:19 PM • EliteGroup ECS... • Answered on Sep 02, 2015
Drivers disco duro hp pd 500a
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/home?sp4ts.oid=5179191&ac.admitted=1401035468572.876444892.492883150
5/25/2014 4:32:02 PM • EliteGroup ECS... • Answered on May 25, 2014
2answers
H61H2M2 Motherboard F_panel
Hello the manual can be downloaded here:http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?detailid=1228&MenuID=0&LanID=011_24_2012_6_17_42_pm.jpg11_24_2012_6_18_14_pm.jpgHard Drive Activity LEDConnecting pins 1 and 3 to a front panel mounted LED provides visual indication thatdata is being read from or written to the hard drive. For the LED to function properly,an IDE drive should be connected to the onboard IDE interface. The LED will alsoshow activity for devices connected to the SCSI (hard drive activity LED) connector.Power/Sleep/Message waiting LEDConnecting pins 2 and 4 to a single or dual-color, front panel mounted LED providespower on/off, sleep, and message waiting indication.Reset SwitchSupporting the reset function requires connecting pin 5 and 7 to a momentarycontactswitch that is normally open. When the switch is closed, the board resets andruns POST.Power SwitchSupporting the power on/off function requires connecting pins 6 and 8 to a momentary-contact switch that is normally open. The switch should maintain contact for atleast 50 ms to signal the power supply to switch on or off. The time requirement isdue to internal de-bounce circuitry. After receiving a power on/off signal, at least twoseconds elapses before the power supply recognizes another on/off signalGood luck
11/24/2012 6:28:54 PM • EliteGroup ECS... • Answered on Nov 24, 2012
Sm bus controller driver-ecs-H61H2-M2
Google unknown device identifier and download and run it.
10/14/2012 3:34:09 PM • EliteGroup ECS... • Answered on Oct 14, 2012
Where can i find a free download of the driver needed to fix the sm bus controller driver that is missing in my computer mother board ECS-H61H2-M2
Hello,You need the Intel iAMT Driver from Intel's website from here.Regards,Dennis E. Mungai
10/14/2012 2:59:08 PM • EliteGroup ECS... • Answered on Oct 14, 2012
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
8/15/2015 1:38:38 AM • EliteGroup... • Answered on Aug 15, 2015
I cannot find my administration key that is needed at the end of my installation of my motherboard. I cannot find the code in the box. Where is it?
Hi, Could you elaborate? I have never heard of this... unless you are talking about the Administrator password Windows asks for during install... which you can typically just leave blank and continue the install...
1/31/2015 8:52:47 AM • EliteGroup... • Answered on Jan 31, 2015
0answers
0answers
LAPTOP l41sa1
Be the first to answer 6/9/2014 4:31:05 AM • EliteGroup... • Posted on Jun 09, 2014Be the first to answer
Check operator services nokia
http://www.nokia.com/us-en/?dcmpid=bmc-src-google.Brand
6/2/2014 3:49:19 AM • EliteGroup... • Answered on Jun 02, 2014
EliteGroup ECS H61H2M2 Intel H61 Sandy Bridge Motherboard Logo
8 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
drivers disco duro hp pd 500a
  • Computers & Internet
