20 Most Recent
Toshiba Satellite M35X-S109 Notebook Questions & Answers
My laptop problem has start
Here's
how to fix a non booting toshiba or hp laptop. This is a rather common problem with many Toshiba and HP models, where the Maxim power driver chip fails and needs resoldering. It's a tiny 48-pin chip, so if you dont have extensive resoldering experience, you'll need the repair manual. This
Toshiba m35 laptop repair manual comes with 3 resoldering scenarios, so you can pick the one that suits your skills.
All in all, the repair process lasts for about an hour and using the repair guide you should have no problems fixing your dead laptop.
6/6/2011 6:45:52 AM •
Toshiba...
Answered
on Jun 06, 2011
How can i install a
Use card slot (on right side) D-Link wireless adapter DWA-642 works great.
or you can use 1 USB port with a D-Link DWA-125 Wireless adapter
Both are wireless N and backward compatable.
2/23/2011 4:47:51 AM •
Toshiba...
Answered
on Feb 23, 2011
I just went to use my laptop for the first time in
Most likely an LCD backlight inverter chip has gone bad. They're about $15-50 depending on where you go to get one. Ebay is a good option here. There pretty simple to replace and it should be an easy fix for anyone handy with a screw driver. But be careful not to break the bezel of your monitor...
1/4/2011 2:30:23 AM •
Toshiba...
Answered
on Jan 04, 2011
Need rudimentary illustration to disassemble
As a rule, service manuals are not generally available. You can try Toshiba but don't expect miracles. I checked there web page as I'm sure you have and it is not commonly available. Try their tech support and see if they will help.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
10/3/2010 1:45:15 PM •
Toshiba...
Answered
on Oct 03, 2010
I asked this earlier but the solution didn't work.
Hi
You've done all the technical things. Have you tried the simple things? Download AVGFREE, MALWAREBYTES, and SUPERANTISPYWARE. Run these to elimainate any bugs in the system Now go to START, RUN and type CMD. At the C prompt type SFC /scannow. This will force a re installation of Windows files.
8/12/2010 9:01:45 PM •
Toshiba...
Answered
on Aug 12, 2010
I can't connect to the windows update site. When I
Hello Sir,
Try typing these commands and check whether you could access the update page
Commands
Re-register the Windows Update DLL with the commands below
1.)Click Start, click Run, type cmd, and then click OK.
Type the following commands. Press ENTER after each command.
regsvr32 wuapi.dll
regsvr32 wuaueng.dll
regsvr32 wuaueng1.dll
regsvr32 wucltui.dll
regsvr32 wups.dll
regsvr32 wups2.dll
regsvr32 wuweb.dll
8/12/2010 3:10:43 PM •
Toshiba...
Answered
on Aug 12, 2010
