20 Most Recent
Konica Minolta Di3510 AllInOne Laser Printer Questions & Answers
We are using our Konica Minolta Di3510 as our
There is too little information to work out your problem here exactly, but I think here is a conflict in your network. I think you have to read the manual of your modem and printer to see for the settings of your network. Is it DHCP? Do you have a fixed IP address for your printer (that is the best thing to do), and is your Gateway address correct with the correct subnetmask. When your printer starts, it 'asks' for a IP address. Your modem 'gives' an address, but it can be a conflict with an other address in the network. If you set a fixed IP address, your printer will always have the same address and can be found...
So take the time to look carefully to your modem settings: is DHCP on? Which range will it use? What is the Gataway address, what is your subnet mask?
Take also a look at your printer settings: Is DHCP on? Does it have a fixed IP address?
And take a look to your printer driver: to what IP address are you printing? Those three things have to match in order to recognize each other.
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
Good morning, my Konica Minolta 190f says:please call service 001,what will I do to resolve this
Error code 001 is a generic service call error, and it could be related to various problems within the printer.To resolve this issue, follow these steps:
- Power Cycle: Start by turning off the printer, unplugging it from the power source, and waiting for a few minutes. Then, plug it back in and turn it on again. Sometimes, a simple power cycle can clear temporary glitches.
- Check for Obstructions: Ensure that there are no paper jams or any obstructions inside the printer that may be causing the error. Clear any paper jams carefully if you find any.
- Reset Printer: Look for a reset button or a specific key combination in the printer's manual or documentation. Try resetting the printer to its default settings to see if the error clears.
