20 Most Recent Toshiba Satellite A45-S250 Notebook Questions & Answers
Does this happen after the computer has been running for a while? Chances are, the CPU is overheating. Do you hear the fan running at all?
Toshiba... | Answered on Mar 06, 2019
Toshiba Support > Satellite A45-S250 Notebook PC > Atheros 802.11 a/b/g WiFi driver with Cisco WPA support for Windows XP and 2000,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=555703&rpn=PSA40U&modelFilter=A45-S250&selCategory=2756709&selFamily=1073768663
HOWEVER, it requires the Atheros Client Utility v2.4.2.18, to be installed. If it isn't installed on the laptop, this utility needs to be installed first. Then the Driver above.
If you need guidance in downloading, or installing please post in a Comment.
Regards,
joecoolvette
Toshiba... | Answered on Sep 15, 2018
im sorry but i cant help you with this one i did all my best even signed up with it just to try to help you, but this could be my only advice, if your running on vista, and its a program try running it as adminsitrator,
hope that was helpful,
Thanks!
Toshiba... | Answered on Dec 07, 2016
You should check your boot option to fix this problem.
In the boot option, select those options you want to boot from like cd/dvd rom or from USB or HDD.
Toshiba... | Answered on Nov 28, 2013
First try starting the machine without the battery, only the charger, Then check the charger with an ohm meter to see if it's working properly. The out put readings are listed on the charger. In case of a surge, the charger is designed to go out first before damaging the system. However, this is not always the case. If the charger checks good, then you should take it in for a professional diagnostic because the problem may be with the power management system on the motherboard. One thing to keep in mind for future reference is when moving to a different location with your laptop, when unplugging the charger, always unplug the charger from the laptop before unplugging from the wall socket, and when plugging in, always plug the charger into the wall socket before plugging into the laptop. This will keep from surging your system.
Toshiba... | Answered on Nov 11, 2012
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Toshiba... | Answered on Apr 16, 2012
If this a Notebook/laptop, please do not try overclocking, it may damage CPU/other components..
Toshiba... | Answered on Jul 11, 2011
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Toshiba... | Answered on Jun 21, 2011
Unplug the power cord, take out the battery and hold the power button down for 10-15 seconds. This should take your computer out of the reboot loop that it is stuck in. If it doesn't, try using an external CD drive from Wal-Mart or Radio Shack, your computer should register it and you can load the windows CD from there.
Toshiba... | Answered on Mar 12, 2011
Sounds like its life is over and time for a new one. I burn a lot of disks myself and have had to replace quite a few over the yrs. You can do it yourself easy enough theres just 1 screw underneath your laptop holding it in then it just pulls straight out.....cheers and plz vote
Toshiba... | Answered on Jan 26, 2011
toshiba download page. (please put the www. before the link)
csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=555703&rpn=PSA40U&modelFilter=A45-S250&selCategory=2756709&selFamily=1073768663
I think the driver you are looking for is the first on the page -
Good Luck.
Bill
Toshiba... | Answered on Nov 29, 2010
Hi, You can get any capacity or speed you want, The only thing you need to make sure of is that it is an EIDE drive for laptops and that you have all the drivers and software you will need to reinstall everything back onto your laptop after you install the new drive.
Toshiba... | Answered on Aug 18, 2010
If you can, please let me know the Operating System installed on your Laptop. Thanks and awaiting.
Toshiba... | Answered on Aug 02, 2010
Toshiba Satellite A45-S250 Notebook Logo
102 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
no connection thru mate1 com
  • Computers & Internet
