20 Most Recent
Toshiba Satellite M45-S355 (PSM40U073001) PC Notebook Questions & Answers
Ashampoo commander 10 photo editor
you might have to many programs trying to or accessing your computer or the internet at the same time or a virus
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you dont need to be running select end now you might have to either restart the program , restart your computer or reinstall ashampoo commander programhope this helps
3/28/2018 8:24:39 AM •
Toshiba...
Answered
on Mar 28, 2018
I have toshiba m45 and
Enter setup, set it to use legacy mode for USB devices, and move USB to before the HD so it's seen beforehand on the bot menu. F12 will sometimes let you choose the USB device to boot from, but Setup needs to see the device first.
11/27/2017 5:14:55 PM •
Toshiba...
Answered
on Nov 27, 2017
Sd card not read
Download the driver for card reader and install it.
8/11/2013 12:40:08 PM •
Toshiba...
Answered
on Aug 11, 2013
How to speed up my pc?
You can speed up your laptop by installing more RAM, at least 1Gb or more.ALSO Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
10/4/2012 6:47:29 AM •
Toshiba...
Answered
on Oct 04, 2012
My toshiba satellite m45-s355 seems
like other prblem on keyboard it seems your fn key was stuck, it can caused the keyboard was dirty, just open the keyboard then remove all the key on your keyboard then clean it using alcohol wait until dry then set the key again
1/14/2011 3:22:30 PM •
Toshiba...
Answered
on Jan 14, 2011
ON my Toshiba Satellite M-45 S355 I got a blue
do not believe you need replace the hard drive
i think you may have a registry error
you may have a application conflict or surface error
try booting in either step mode or safe mode
step mode will let you know where in the boot process the error occures
in safe mode you can run a registry utility like iolo system / registry mechanic
& run error checking
if you need neer to remove & backup your drive you can get a hard drive usb adapter cable set $10-$20 - less work
11/5/2010 4:44:36 AM •
Toshiba...
Answered
on Nov 05, 2010
Goes to windows screen then
seems like a driver crash,,
restart computer
keep pressing F8
Select safe mode
Click No you want to use system restore
restore your pc to a few days back when it worked good
(follow on screen instructions)
That is you should be fine..
11/1/2010 3:57:16 PM •
Toshiba...
Answered
on Nov 01, 2010
Toshiba m45-s355 reformat from usb
Hi
Thak you for yor query
To ensure the CD/DVD is clean please try booting from a known working PC, from what you are describing it may not be your CD drive
If the same thing happnes on another PC then it is the CD/DVD that is faulty, however if it works, then you can try to hook up a external drive, the laptop may defualt to it after trying all the other options i.e. CD rom drive, HDD etc
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If this has been useful please leave positive feedback/vote/Testimonial - it will be highly appreciated
2/12/2010 7:16:49 PM •
Toshiba...
Answered
on Feb 12, 2010
My screen is black even can't do anything
You may try to plug in an external monitor to the rear aux monitor connector on the laptop. Be sure to depress the key that switches the monitor to external while is powering up. If you get an image/picture on the external monitor it is probably the connector that has come loose from the mother board. WARNING!!! You have to take out alot of screws and sub components to get at it if you can attempt to lift the keyboard up and remove it first. You may be able to access the connector from there. If you attempt any major dismantling, video tape yourself doing it. That tape may prove invaluable when it comes to putting it back together.
12/17/2009 2:04:36 AM •
Toshiba...
Answered
on Dec 17, 2009
Toshiba Satellite M45-S355 PC notebook modem
The 678 error means that the modem is not connecting to the server because of problem at the server end. Contact the helpline of your service provider and ask them to rectify the problem at their end.
11/17/2009 5:35:59 PM •
Toshiba...
Answered
on Nov 17, 2009
I read that a recall on the Toshiba Satellite
I cannot find any record of a recall being issued but typically a recall will state the serial number range for affected units. Not all units will be affected since they have several plants manufacturing them and defects are usually an isolated case from a specific facility. Without that information, I wouldn't know how else you can verify whether your unit is one of the affected models or not.
10/4/2009 9:52:10 PM •
Toshiba...
Answered
on Oct 04, 2009
A incorrect product key No
Make sure that the verion of windows u wanna install is the same if not if u are installing pirate version then its normally cracked and u dont need to set cd key
1/27/2009 12:24:39 AM •
Toshiba...
Answered
on Jan 27, 2009
