20 Most Recent
Toshiba Satellite Pro M15-S405 Notebook Questions & Answers
Lan wireless connection
identify moel # to better assist. for Toshiba, i own one , the config utility is only needed to search for a wireless first, then it will reset. sounds like you have too many wireless setup installed, go into the internet connection section and see waht wireless setups there are and delete same. you will want a new install.
\MAKE sure if you are using a wired connection hat same is turned OFF when trying to do a wireless.
1/9/2017 6:07:08 AM •
Toshiba...
Answered
on Jan 09, 2017
Cooked motherboard, blown fuse, blown power pack.......
It's time to take the laptop to a qualified technician; if there is a fuse, then it is _not_ an "end-user" task to disassemble the laptop, to change the fuse. If it is _not_ a fuse, then the technician needs to do more trouble-shooting than what you, as a "user", currently know how to do.
1/23/2015 11:31:28 PM •
Toshiba...
Answered
on Jan 23, 2015
How can i reset a toshiba satellite pro m15 s405
Most Toshiba laptops with come with the factory software recovery image stored in a special hidden partition on the hard drive of the laptop. The factory software recovery image allows the user to recover the laptop to its factory fresh condition as when it was new.
This partition may also be referred to as the Partitioned Recovery Method or Free Recovery option.
IMPORTANT: The recovery process deletes information stored on the internal storage drive. Be sure to save your work to external media before executing the recovery.
- Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
- Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
- Make sure the AC Adapter is plugged in and working.
- On machines with the F key numbers on the top edge of the keys and in White:
• Press and hold the 0 (zero) key and power up the laptop.
• Release the 0 (zero) key when the recovery warning screen appears.
On machines with the F key numbers on the bottom edge of the keys and in Gray:
• Power up the laptop.
• When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
• Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
- The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
- After you are sure you have everything you want from the laptop saved, click Yes.
- When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
- After selecting your desired recovery method, select Next.
- On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
- Select next to continue.
- Follow the on screen instructions as you navigate through the system recovery steps.
- The laptop will restart multiple times and install the needed components.
11/25/2014 11:42:32 AM •
Toshiba...
Answered
on Nov 25, 2014
My laptop (Toshiba Satellite Pro M70) freezes (a
There's no M70 model, so I'm assuming you're talking abut a Satellite Pro M10, M15 series laptop. If the slightest movement hangs it or causes BSOD, then my guess is ... well ... I'll let you have it: the weaknesses of this models are: (1) bad memory socket (the upper socket),or (2) bad sound card socket. The one that's easiest to access is the upper memory socket - remove the installed memory from that socket, and see if your machine will still hang or blue-screen. I don't know if anyone still fixes these sockets (I do), but you can get around it by installing a larger capacity memory into the lower socket and skipping the upper socket altogether.
1/28/2013 11:14:48 PM •
Toshiba...
Answered
on Jan 28, 2013
