20 Most Recent Toshiba Satellite 2435-S255 Notebook Questions & Answers
Windows XP starts then restarts over and over
Heaps of things can cause this - corrupt software, corrupt OS, virus, hard disk error. etcFirst of all, I'd try turning the pc on, press the F8 key repeatedly until you get a list of options in dos mode text.The first one listed will be safe mode.use the arrow keys to select Last Known Good Configuration.press enter, and, if you are in luck, your system will boot up just like normal.This has fixed numerous pcs in the past. If it works, I'd advise doing a checkdisk on the hard disk and running an AV scan, just to make sure.If that fails, I'd again press F* repeatedly on boot, then select safe mode.Wait ages, until you get a prompt with heaps of text, with yes to go to safe mode, no to go to system restore.Select NO, and the system restore wizard will start... select a date previous to when the issue started, wait a while, and then test. if that goes thru, but the system still wont boot, i'd rerun system restore, but choose an earlier restore point.If that fails, you'll need to boot from an XP disk, home or pro - the one that matches your OS - home or pro... boot from the cd, at first screen press r to repair via the recovery console.select your os partition ( usually just press 1) put in your admin password (usually just press enter, unless one is set)and, when you can see the command line...type in chkdsk /r c:and press enter.this will check and repair, if possible, any faults on the hard disk. once this completes, reboot and retest.If that fails, you'll need to again boot from an XP disk, at the first screen press enter to install OS, press F8 to accept the licence agreement... then, if and ONLY if you get the option to press "r" to repair, press R, and allow it to repair the OS. DO NOT CONTINUE PAST THIS SCREEN OR CHOOSE ANY OTHER OPTION OTHER THAN R, as you will OVERWRITE YOUR DATA. To reiterate, if you don't get the option to press R to repair STOP, or otherwise say goodbye to your files. you will not get the option to repair if you either are using the wrong xp disk, ie home disk with pro OS, or vice versa, or if the hard disk is corrupt, or the OS is too badly damaged to be recognised...Hope this info helps.
7/12/2019 7:36:42 AM • Toshiba... • Answered on Jul 12, 2019
0answers
Speakers not working on laptop
Do a windows update. It will search for the best available drivers for your laptop now select only the one with the name "realtek high definition sound drivers. And download it. Install it. And now restart your laptop sound will work.
1/5/2014 4:12:08 PM • Toshiba... • Answered on Jan 05, 2014
0answers
2answers
I have a Toshiba 2435-s255 laptop. I want to add
You can put (2) 1 GB sticks in that computer and you would see very, very fast results and the machine will thank you for the upgrade because it will not have to work as hard. Just remember though that you still have the same processor as you did before so if that is the bottleneck in the system, then it will run as fast as the processor allows it. The extra RAM will free up 90% of bottleneck issues.
12/9/2011 5:08:20 AM • Toshiba... • Answered on Dec 09, 2011
Reset cmos password satellite 2435-s255
Check my hint at: http://www1.fixya.com/support/r5953318-reset_bios_password
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
10/1/2011 8:19:16 PM • Toshiba... • Answered on Oct 01, 2011
How can I relace all
You're telling me that this RealTek AC'97 audio driver will not work?
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=321480&rpn=PS243U&modelFilter=2435-S255&selCategory=2756709&selFamily=1073768663
Click on the Downloads tab, then click on page 2 at the bottom.
01-07-2003, Driver Sound, Realtek Audio Driver for Windows XP/2000 (v.5.10.00.4010; 12-03-2002;2.53M)
How are you downloading, and installing it?
Post back in a Comment.
Regards,
joecoolvette
9/5/2011 1:02:37 PM • Toshiba... • Answered on Sep 05, 2011
How to unlock my toshiba 2435-s255 bios
pull out the cmos battery as well as the battery, and leave it for 3 minutes. then put the reg. battery back in and boot it up. it should say password disabled. Turn it off and put the cmos battery back in, it should work now. leave positive feedback!
1/13/2011 6:46:29 PM • Toshiba... • Answered on Jan 13, 2011
0answers
Can't get in toshiba satellite
Not good news I'm afraid. Refer to this Toshiba support bulletin. You will need to send your laptop into a Toshiba Authorised Service Provider to get the problem fixed.
9/3/2010 10:30:07 AM • Toshiba... • Answered on Sep 03, 2010
2answers
MY DVD PROGRAM IS NOT WORKING ON LAPTOP
Download the codecs needed. You can also download a media player with built in codecs, try VLC player from videolan (google it)
8/3/2010 6:11:53 PM • Toshiba... • Answered on Aug 03, 2010
2answers
What kind of thermal grease CPU I can use for replace old grease
Depends what you intend to do with your computer, if its lots of gaming, and pushing your pc to its limits, you will need a good quality thermal compound (arctic silver), if its just normal stuff a cheaper heat sink compound will do, i use Servisol, its cheap and works well
7/16/2010 9:54:28 PM • Toshiba... • Answered on Jul 16, 2010
HELLO HOW R U DOING TODAY?
find the make and model of the dvd drive, and look for updates in the software that control it
7/4/2010 2:52:23 AM • Toshiba... • Answered on Jul 04, 2010
Toshiba 2435 s255 notebook shutsdown and fan runs on high speed
Overheating problem is caused by faulty fan and or the fan and heat-sink assembly is clogged with dust.
When the CPU overheats, it goes into thermal shutdown and won't boot up again until the CPU has cooled down. If this problem is not fixed, eventually the CPU will fail completely. The fan must spin freely, if not replace the faulty fan.
Check the fan and heat-sink and loosen and vacuum/remove the dust from the fan and heat-sink assembly. Depending upon the model of your Toshiba, the fan can be accessed from the bottom of the laptop or you may need to remove the keyboard to get at the fan and heat-sink.
1/22/2010 6:12:07 AM • Toshiba... • Answered on Jan 22, 2010
Toshiba Satellite 2435-S255 Notebook Logo
Popular Tags
36 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
restore toshiba laptop windows xp
  • Computers & Internet
