20 Most Recent
Tommy Hilfiger 1790654 Watch for Men Questions & Answers
Does anyone know how to adjust dual time. Cant seem to adjust the second time..Tommy Hilfiger 1791709
To adjust the dual time on a Tommy Hilfiger 1791709 watch, you will need to follow these steps:
- Locate the crown (knob) on the side of the watch.
- Pull the crown out to the second position. You should feel a slight resistance as you do this.
- Turn the crown clockwise or counterclockwise to adjust the time on the second time zone. The time on the main display will not change.
- When you have set the correct time, push the crown back in to the original position.
It is important to refer to the user manual for your specific watch model for detailed instructions on how to adjust the dual time feature. If you are unable to adjust the dual time on your watch, it is recommended to have it serviced by a professional watch repair technician.
I was given a tommy
One of the twist setting knobs may also be a digital, try holding for 10 secs, then date will blink, use other kn9b to toggle up and down, then return original , press once to set.
