20 Most Recent
Keyspan SX Pro (SX-PRO4) Serial Adapter Questions & Answers
Keyspan SX Pro Serial Adapter set up
Do you have the driver cd of the card. For setting up a PCI card simply insert it in the pci slot and install drivers when it asks you.
I think your PCI card needs drivers
Can't set up to use.
this should work with OS 8.1 or greater, as long as your slot is 5v and not 3.3v but there are serial printer port driver issues, but nothing other than the usual, see below
http://www.keyspan.com/products/sxpro/homepage.2.reqs.spml
http://www.keyspan.com/products/sxpro/homepage.2.compat.spml
Usb doesnt recognize serial device
You didn't mention exactly what keyspan device you're trying to install. That's some pretty important information, but I'm going to make a suggestion based on what I've got at this moment. If you need more, you've got to give more info.
I'm assuming that if there is a power supply for your device, it is plugged in and working properly. Do you have the drivers installed for the end device? If not, the device might not be backward compatible. Your best bet would be to simply run it on an older computer, if you can.
If it was me, I think I'd carefully check the pins on the device you're trying to adapt to USB. Those pins are pretty delicate, compared to USB. One bent or missing data pin and it might not work.
11/28/2013 3:08:24 AM •
Keyspan...
Answered
on Nov 28, 2013
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
