20 Most Recent
Kodak DC280 Zoom Digital Camera Questions & Answers
I need a device driver
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Kodak DC 280
Unable to download
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
I need the instructions for my dc 280 kodac.
You can view the manual online and/or download the manual in PDF form from the manufacturer's web site at
http://www.kodak.com/global/en/service/products/ekn006595.jhtml?pq-path=690
DC280 Kodak Camera- Everything is working fine
Take the batteries out of the camera and let it sit for around an hour. Turn your dial to "set up", then put the batteries back in and turn the camera on, it should ask you to reset the date and time on the LCD. If it doesn't, your camera is essentially dead. Buy a new Panasonic FZ35 if you can afford it. Best All Around Camera I have ever had including the more expensive SLRs.
Broken Batttery door.
I just bought one for less than $15 including shipment from uscamera.com . Item was shipped promptly.
My kodak easy share M380 digital camera froze as I was turning it
This problem is frequently due to corroded battery terminals inside the
camera. Remove the batteries and wipe the terminals with a soft cloth
(heavy corrosion may require a fine wire brush, steel wool, or
sandpaper). Remove any residue left in the camera by the cleaning.
Clean the terminals on the batteries in the same manner, and then
replace them in the camera. This cures most problems, but if it
doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
