20 Most Recent Kodak EasyShare CX6330 Digital Camera Questions & Answers
I am looking to source a part for a Dewalt 740
Dewalt radial saw ASP 2225-03 17 A 120-240
1/2/2017 4:44:44 PM • Kodak EasyShare... • Answered on Jan 02, 2017
0answers
Memory card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1/29/2013 7:44:10 PM • Kodak EasyShare... • Answered on Jan 29, 2013
My kodak cx6330 lens is stuck keep showing me
Go to this website for possible solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
10/21/2011 8:44:04 PM • Kodak EasyShare... • Answered on Oct 21, 2011
Can photos be transferred from
Follow the instructions on this page of the user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg00137/urg00137c4s10.shtml
5/16/2011 8:47:18 PM • Kodak EasyShare... • Answered on May 16, 2011
I NEED A MEMORY CARD
You should be able to find SD cards in any department, electronics, or office-supply store. Just make sure you get an SD card, not an SDHC card.
4/18/2011 4:33:47 PM • Kodak EasyShare... • Answered on Apr 18, 2011
Formating memory card 4.0 gb
Check your manual to see if you can use a 4GB card.
12/23/2010 10:21:33 PM • Kodak EasyShare... • Answered on Dec 23, 2010
I was able to download all pictures to my
Try formatting the memory card. There will be a function in the camera for this. It will delete everything on the card, but you have already saved your pics. Copying the pics to your computer does not remove them from the card, unless you "move" them instead of "copy".
11/21/2010 9:59:12 PM • Kodak EasyShare... • Answered on Nov 21, 2010
Our zoom lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
10/28/2010 9:18:53 PM • Kodak EasyShare... • Answered on Oct 28, 2010
Hi, I've lost the CD with
You can download the software from the Kodak site, using:
This link
10/18/2010 4:20:53 PM • Kodak EasyShare... • Answered on Oct 18, 2010
How do I format a
Go into the menu and find "format"...follow the on-screen instructions.
10/17/2010 1:24:07 AM • Kodak EasyShare... • Answered on Oct 17, 2010
I have a kodak easy
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Let me know if you need further assistance.
Regards
Andrea
9/3/2010 8:45:25 PM • Kodak EasyShare... • Answered on Sep 03, 2010
I tried using a 4GB SDHC card on my Kodak
The CX6330 is designed to work with SD and MMC cards. It will not work with SDHC cards. You need to use SD cards 2GB and smaller.
You cannot use the card on the camera. If you have a card reader or other device compatible with SDHC cards, you should be able to format the card there.
9/2/2010 7:02:20 PM • Kodak EasyShare... • Answered on Sep 02, 2010
Battery door on Kodak easy share CX6330 will not stay closed
http://uscamera.com/1kod003.htm
6/14/2010 10:50:01 PM • Kodak EasyShare... • Answered on Jun 14, 2010
I installed a new 4 GB memory card and my camera
Your camera does probably not support SDHC cards. You can use cards up to 2GB.
5/17/2010 12:15:22 PM • Kodak EasyShare... • Answered on May 17, 2010
Ihave a Kodak cx6330, I was wondering if it will
Camera never works with the windows system. We just access our cams through systems..... Definitely you can access your camera through Windows 7. For that you just have to download the driver for you cam from the given link......http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=1114/1119&product=EKN026823&operatingSystem=windows_7
Please rate the answer
4/30/2010 2:35:26 PM • Kodak EasyShare... • Answered on Apr 30, 2010
I have a Kodak cx6330, will this camera work with
Camera never works with the windows system. We just access our cams through systems..... Definitely you can access your camera through Windows 7. For that you just have to download the driver for you cam from the given link...... http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=1114/1119&product=EKN026823&operatingSystem=windows_7
4/30/2010 2:32:39 PM • Kodak EasyShare... • Answered on Apr 30, 2010
Camera won't power on with
Hello
Ok, firstly, tis sounds to me ike a battery problem. When last have you changed the camera batteries?
And if the camera goes on after you have charged it, does it actually function normally?
Also, you need to remember, that your camera needs certain batteries to operate normally. Alkaline batteries will not do the trick, you need rechargable lithium or NiMH batteries. Please give mefeedback.
Please do not hessitate to let me know if you need any further assistance.
Kind regards
Andrea
1/19/2010 10:07:51 PM • Kodak EasyShare... • Answered on Jan 19, 2010
Kodak EasyShare CX6330 Digital Camera Logo
41 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
memory card protected
  • Cameras
