20 Most Recent
Kyocera Finecam S4 Digital Camera Questions & Answers
Won't power up upon pressing on button, flash
Due to the tight tolerances inside the lense mechanism - small bits of sand or lint may become trapped in the mechanics.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned.
There are many small parts and intricacies that will render it totally useless if not done properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Problem in the camera
The Kyocera web site tech support, will have that information
Manually pulling and pushing a stuck zoom lens will run it,
It is a very delicate mechanism, and there will be no service option if it is broken.
I have c1 error
c1 error is caused by Dirt /dust in the lens and lens gear box ( this drives zooming only )
preventing optimum functioning. Lens cannot properly come on line (
shutter and diaphragh mechanism then do not come on line ) and the camera
switches off. Solution : is ether replace lens unit or dismantle lens
to clean out ( from gear box and the helicoil of the lens ).
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Camera will not stay on!
Kyocera online Technical Support team- should sort this for you - it is I thing a switch fault and the camera should be replaced- if it is out of warranty a nominal fee will be charged.
