20 Most Recent
LG DVX583KH Player Questions & Answers
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Reset dvd player
The player works off the source..the 16:9 is a function of source and your tv display (usually denoted as "wide" key on the remote)
My DVD is playing my videos in black and white
follow the steps:No picture o colors
- Make sure all power cords are
connected.,cllean the cables from oxide or corrosion.
- Try pressing the
enter/play key.
- Make sure the TV is turned on
and the input is set properly.
- Make sure the TV source is set
properly on the TV (This is probably done on the screen;
Check your TV manual).
Dvx583kh no sound HDMI
you must read your instrc.manual from TV +DVD about the connection is compatible. or some connection is wrong. download your instruction manual go www.fitness.manualonline.com or www. retrevo.com see the diagram connection God bless you
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
