20 Most Recent
NetGear N300 Wireless Router Questions & Answers
Mywifiext login
Do you have the range extender set up on the same live in the fuse box? If you have the one side on a breaker on the opposite side of the fuse box from the othrr side, it will not work well at all. That is why I encourage people not to waste their money on these things and get a decent wireless system so that you dont have problems.
Have NetGear N300 wireless router (wnr 2000v2)fed
hi, go straight from your motorola to each wired computer to see if its a wire.can you can login to the router through your wired computer(touchsmart) in the settings and see if all your wired devices are listed, look at the parental controls, reset the whole router to default if you can, if your DSL. try a different jack in the house, get everything off that line but the motorola. go straight from the service jack outside the house(in the grey box) if you have tojm
Netgear N300 Firewall setting
wait you using DHCP? What's to stop the computer from releasing the dhcp lease and obtain a new IP besides the 192.168.0.5 that you are blocking?
Does it support windows 8. The box says windows 7
I don't think it matters, as only the install program requires Windows 7.
If you install it manually on wireless you should not have a problem with Windows 8.
Most Windows 8 machines have Wi-I built-in and so do not require a driver as it is already fitted.
See manual for router.
N300 WiFi Router
