20 Most Recent Linksys EtherFast 10/100 16-Port Workgroup Switch [ EZXS16W ] (104834) Questions & Answers
When your 10 computers are connected to the switch, just make sure your ethernet cable is plugged into the ethernet port. The computers should then have a internet connection
Linksys... | Answered on Mar 09, 2018
right click on the projector an click on the properties tab
click on compatibility tab
tick the box and click on win 7---apply and ok
if it worked on win xp and you changed to win7 and doesn't work indicates a compatibility problem or driver for it in win 7
Linksys... | Answered on Apr 06, 2017
Let's check some settings for the network connections. Click on "start" - "settings" - "control panel" - "network connections".
First we'll check the ethernet connection. Right click on "local area connection" - "properties" - choose "Internet protocol (TCP/IP)" - "properties". In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically".
Click on OK at both windows.
Now we'll check the Wi-fi connection. Right click on "Wireless connection" - "properties" - choose "Internet protocol (TCP/IP)" - "properties". In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically".
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Linksys... | Answered on Sep 18, 2010
Hi, by default the Linksys router is set to DHCP... So all you have to do is connect an ethernet cable from your modem to the WAN/Internet port of the router and then connect a PC to one of the ports, see if that will be able to connect to the Internet if not, try to do a power cycle (turned off everything and then turn on the modem first and wait for all the lights to be stable and turn on the router and then the PC) once the computer gets online you may connect the rest... should you require to connect more than 4 PCs, you may need to have a switch but with this setup the physical connection should be
Modem to WAN port of the Router to Switch port and all PC should be connected to the Switch's ports
Linksys... | Answered on Jul 24, 2010
I can give you the full manual of that product bro but you should have to install a foxit reader in order to read the file or the manual. First intall this software: http://www.mediafire.com/?nyowk0a5yqm Linksys EZXS16W manual: http://www.mediafire.com/?tgkdwnkjz1g
Linksys... | Answered on May 14, 2010
Depending on what model of "modem" you have you may not be able to. If the Motorola unit is just a modem (not a gateway) then you can't, and you don't need to. There is nothing that needs to be configured in a modem.
If the "modem" is a gateway (a modem and router in one physical unit) then you need to open a browser (Internet Explorer) and enter in the IP of the router. For example, http://192.168.1.1. Depending on the model of the unit, that IP address (the numbers) may be different that what I typed. You can determine what IP address it is by looking at the product documentation, or double-clicking on your network connection icon in Windows and reading the "Default Gateway" address.
Once you get the correct IP address entered into the browser, the page for the web interface will load. That is where you can configure it.
Linksys... | Answered on Jan 20, 2010
Hi There, first of all you need to connect from your modem or router's port a link. Use a cat5 ethernet cable from the modem to the switch or if you also use a router from a port in back to the switch. Then when you plug in other computers it will see the internet connection. Good Luck...
Linksys... | Answered on Oct 28, 2009
Could be over heating let it cool meaning complete shut off unpluged 20 mins for all heat to removed. Then check how long it stays on. If it last more than a few mins it is over heating. You need to try to get all dust out of it and try it again. If this time the link is lost after a few mins or hours its was over heating. Also at this point it could be a bad component over heting and a new router is need.
This could be one of many problems good luck.
Linksys... | Answered on Sep 09, 2009
if they are blinking green, they are all working.
check your cable if they have continuity and also if they are patch cable
Linksys... | Answered on Sep 05, 2009
hi try 192.168.1.1
hope this helps
cheers
Linksys... | Answered on Jun 28, 2009
hello.just a simple way to install..don't plug in the router on the CPU then install 1st the CD installer step by step.after install the driver reboot the unit then after booting plug in the Router wire on the Lan/Network..Good Luck...Thanks..Have a Nice Day...^_^
Linksys... | Answered on May 17, 2009
you might need a router instead of a switch.
what is the model number of the modem?
Linksys... | Answered on Feb 20, 2009
For Linksys routers there is no username only the password which is admin.
Linksys... | Answered on Jan 09, 2009
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Linksys... | Answered on Jan 01, 2009
https://www.linksys.com/ca/support-article?articleNum=140923
Which model?
Go to the Linksys website and download the instructions for your model of extender.
Linksys... | Answered on Dec 02, 2019
There are several factors that will affect or can cause problems in connecting your Roku to your Router.
If you're getting an error message on Roku like 014, 011, make sure to indicate it in your response. Normally, if you're getting 014 message, you can follow these steps:
. A simple power cycle resolves most of the issues. To perform a power cycle, please follow the instructions below:
1. Unplug the power cables from the modem, router and the Roku player.
2. Connect the power cable to the modem (after a minute). Once all the lights on the modem are lit, plug in
the power cable to the router and then to the Roku player.
3. Go to "Settings" and redo the complete Roku setup.
If the issue continues to occur, please try the channel 1 or 3. Should it persist, you may reset the Roku
player. Here is how:
On the back or bottom of the Roku unit, you should find a recessed little hole.
- Use a pin or paperclip to press and hold the button for 30 seconds (please ensure that the power light
blinks while you are holding it down).
The Roku device will reset to default and be ready for setup again.
If the problem continues, please reflash the software via the secret screen:
1. Press the "Home" button for 5 times.
2. Press the "Forward" button for 3 times.
3. Press the "Rewind" button twice.
4. Choose Update Software and the Roku player will then restart.
You can comment your serial number or the error message that you're getting. If your getting 011, just power cycle your entire network. Also, please make sure that you're not connecting the Roku to a Guest network. The speed of your connection matters as well. It should be atleast 1.5mbps.
Linksys... | Answered on Nov 23, 2019
The vent actuators are bad. there should be two. one on each side. they are small toy like motors that open and close the vents from within to allow the hot air to blow by closing the vents to the a/c unit.
Linksys... | Answered on Nov 21, 2019
Linksys EtherFast 10/100 16-Port Workgroup Switch [ EZXS16W ] (104834) Logo
Popular Tags
19 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
linksys ezxs16w switch ports
  • Computers & Internet
