20 Most Recent
Umax Astra 2400S Flatbed Scanner Questions & Answers
SCSI to USB Cable or Converter for Astra 2400S Scanner?
You need a Firewire/ SCSI adapter. Mine is a Belkin F5U541. Then simply connect a SCSI cable from the scanner to the adapter & a Firewire cable from the adapter to your Mac. I'm using my old Umax Astra 2400S w/ a G5 iMac running OSX 10.6.7. I had to upgrade my old copy of VueScan, however, to run on Snow Leopard
Error message 00004700h
This souns like a memory error, where the scan is too large for the pc to cope as other programmes running have taken their peice of your RAM, other than that, uninstall the diver in Add/Remove programmes, disconnect scanner.
Re-install driver and re connect scanner when prompted and see if the fault goes away.
Please rate solution.
Filehippo umax scanner 5600drivers
This worked for me umax astra 5600
Hi First download driver from
driver.
Install with comparability in 2000 windows and run as admin,after installation
go to device manager manually select driver from imaging devices and select samsung scx-....... the first one whatever comes there.
Restart and rock.
