20 Most Recent
Apple iPad 2 tablet 16GB 3G Questions & Answers
How do you permanently delete a previously deleted photo from an iPad 2?
You can delete photos in "Recently Deleted" folder in iPad to permanently delete previously deleted photos. And you can also delete photos in iCloud. In addition, you can still reset iPhone to factory settings to reach this aim. Just follow below steps.
You just need to go to "Settings > General > Reset" and then choose the categories you want to reset and then apply it. If you choose "Reset All Contents and Settings", then you will get all the files in your iPhone erased.
Once you tap on "Erase All Content and Settings", you will be asked to enter your Apple ID password. Next, you will see a Popup Message informing you that All media, data and settings will be erased from your iPhone. Click on Erase iPhone to factory reset iPhone 6 Plus.
For more details, check:
How to Restore iPhone to Factory Settings
2 ipad problems
By replacing the screen you have to connect 3 ribbon cables.One of them is the digitiser (touch panel) and most likely this connection isn't good. Usually i check this while the iPad is still open.
My I pad lost the colours and turned white and blak how can I fix it
- Hi, have you activated the Reverse colours function? Go to Settings / General / Accessibility / Invert Colours
- did you drop it by any chance? My boy dropped his and we got the dreaded black screen one time - then we gave it the hard smack treatment on the backside to release the jammed accelerometer - this worked perfectly the 1st time it happened, the 2nd time he dropped it we reverted to strange black and white colours, the smacking continued, and the colours came back.
How do I enable my iPad16GB?
the storage is automatically there, you could reset the ipad giving you a fresh start.
Got to settings then general then reset to remove everything and restore the ipad back to factory settings, this would give you the 16gb of storage back for use but also wipe out all the data. I’m happy to help further over the phone at
https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Fix ipad 2 glass
Sorry, but I think you need to take it to an authorised Apple repair shop (or Apple Store) to change the screen... If it still works, you could try and fill some clear glue or silicon in the cracks as a temporary measure, but it sounds like cutting yourself is easy...
I am wanting to get rid of pop up on my Facebook. Apple 2
Ads and pop up videos on Facebook there is no settings to turn them off from the Facebook settings, there is a setting to block pop ups in safari preferences on the Mac Pro but not sure with the iPad, try going into the safari preferences on the iPad if it has the option to block pop ups turn that setting on and the restart the iPad ie on/off, if no option to block then stumped
Ios 6 download install
If you're still on iOS6, you should open 'Settings', 'General' and go to 'Software Update'.
You may also connect the iPad to your computer, open iTunes and Check for Update. iTunes will download and update for you.
If you're on iOS7 and want to downgrade, that's a problem. You need to google this as it is complicated, and probably not possible.
Why can't I get into updates on my ipad?
you'll need to connect to itunes and restore your ipad as new because it has a software bug.. you must not back up when you restore because the bug will not dissappear, you will lose everything though.
