20 Most Recent
Linksys Wireless-G WPS54GU2 Print Server Questions & Answers
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
12/29/2013 10:14:14 PM •
Linksys...
Answered
on Dec 29, 2013
Wireless-G WPS54GU2 Print Server Lost disk
if you visit the LinkSys website you should be able to download all applicable drivers and files for this print server. Also you will likely be able to access a user manual (in PDF format) which should give you all the information you need.
1/14/2011 8:52:36 PM •
Linksys...
Answered
on Jan 14, 2011
Do you know how to set up the WPS54GU2 printer
After starting the Add Printer Wizard, the trick is to select Local Printer
Attached to This Computer. This is counter-intuitive, but you're not
connecting to the printer using MICROSOFT Networking, so MS doesn't consider
this to be a network printer. Don't select Automatically Detect with Plug
and Play.
On the Select a Printer Port screen, choose Create a New Port. Type of Port
= Standard TCP/IP Port.
Be sure that the printer server and the printer are ready before proceeding.
For Printer Name or IP Address enter the print server's IP address. The
protocol is LPR. You'll need to get the Queue Name from the print server
documentation. It's probably "lp" (that's a lower-case el, not a capital
eye).
11/15/2010 5:05:05 PM •
Linksys...
Answered
on Nov 15, 2010
Well you please tell me
Installation of WPS54G Print Server
Using standard TCP/IP Procedure (Windows XP/2000)
- Make sure your printer already has its drivers installed on all PC's prior to attempting to install this print server.
- Be sure also that your printer can print when it is connected directly to your computer.
- Click on Start go to Printers and Faxes.
- Right click your printer and go to Properties.
- Click on the Ports Tab on the top.
- Click Add Port. Select Create a new port: and select the Type of port: Standard TCP/IP Port, click Next.
- This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
- Inthe field for Printer Name or IP Address: enter the IP address of thePrint Server and click Next. (You can get the IP address of your printserver by pressing the reset button on your device for 3 seconds thenit will print out it's status).
- Select Custom, click Settings.
- Under Protocol select LPR, and for Queue Name: type L1. Click Ok, then Next, and Finish.
Youshould be able to print on the device afterwards. You can refer to yourRouter's Wireless Settings and match them on the WPS54G so that theywould be able to communicate wirelessly.
2/24/2009 7:01:27 AM •
Linksys...
Answered
on Feb 24, 2009
Linksys and HP All in one
great if ur laptops r acessing the internet ... perform the followings ....
> open the page of the print server and try to match the wireless settings of the router on it and u will be able to use the printer as well ....
11/27/2008 6:52:50 AM •
Linksys...
Answered
on Nov 27, 2008
Wireless franctic
generally speaking any compatable wifi unit should work with any other unit.. In saying that yes it is "Better" to get all the same make if one can.. but not essential.
8/3/2007 3:44:28 AM •
Linksys...
Answered
on Aug 03, 2007
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
How to Fix Linksys Router Error 2118?
This seems to be a symptom of a configuration error, which can be fixed by resetting the router to factory default. Do this by finding the (often partially hidden) reset button on the device, and pressing and holding down the button, with the power on, till lights start flashing on the router. Let go of the button and allow the router to reset (can take a minute or two). You will now have reset the router to factory default. To connect to your ISP, you'll need to enter your account details (and any other specific information) provided to you by your ISP. You will also have to set a name and password for the wifi section of your router (if it has wifi) if you don't want it to be freely accessible by everyone within wifi range.
7/29/2021 11:33:41 AM •
Linksys...
Answered
on Jul 29, 2021
Why is my Linksys WRT54G wireless-g router not being recognized anymore?
just fixed one yesterday.
the power pack was no good.AC wall wart,
power green LED blinked endless. and the white logo, LED is dead..
a new pack fixed it.
also the wrong pack used, ! do not mix them up. oops.
first year 54G, v1 uses 5vdc pack.
at v2, and up all want to 12vdc pack,
bottom sticker on above failed was v6.
you said recognized, does that mean the 4 rear Ethernet wired jacks are dead, or just wifi dead.?
first the ethernet ports must work, or wifi is doomed.
2/18/2020 11:46:05 AM •
Linksys...
Answered
on Feb 18, 2020
How to fix Linksys router error 321 ?
Good day,
This might be of help .
Steps To Fix Linksys Router Error 321:-
Step1:- Check the Firewall Settings
To check the Firewall Settings is the first priority for the users. Then check the firewall settings of the computer/ Laptop, will be helpful to find the problem. If there is any firewall installed on the computer, so the users need to turn it OFF.During the process, the users ensure that the Local Area Connection on the computer is not disabled. The Local Area Connection should not have any static IP address assigned. If there is any then the users need to immediately set the IP address to automatic.
Method2:- Run the Installation CD Again:-
The users require trying to run the CD again and ensure when the CD runs, it will ask to connect the computer and the modem to the router with the cable. So the users will need to notice, that there all the lights lit up on the router. If it's not, then users will need to setup their router without the CD.
The users can get the instruction to setup router manually in the method 3.
Step3:- Try to Setup Router Without Installation CD
Setup Linksys Router without Installation CD is another best option for users in order to completely avoid the in order to fix Linksys Router Error 321.
Follow the below-given instruction to Setup Linksys Router without Installation CD:
First of all, connect the main computer to the Ethernet port on the router.
Then the users need to connect the modem to the Internet port on the router.
Now it's time to verify the status of the light that is blinking properly.
Next, users need to open the setup page of the Linksys Router and then change the Internet connection settings manually.
In the setup page of the Linksys Router, the users can change the settings of the router as per their needs.
Then the default IP address of many Linksys router is 192.168.1.1. And the default username and password would be an "admin".
Wait for a few minutes, when the main computer is able to access the Internet, so users need to create a wireless network for their wireless computers/devices.
or you can call them @ Toll Free 1-800-204-6959 that is Lynksys support.
2/3/2020 1:14:25 PM •
Linksys...
Answered
on Feb 03, 2020
