20 Most Recent
Wasp WWS800 Handheld Questions & Answers
How to send information from computer to scanner WWS800 / USB
bar code scanner.
well you need to install the makers software to use that
and the tool came in USB version and Bluetooth.
both need software and later needs Bluetooth working on PC.
The Bluetooth ports are optional on many PCs for sure desktops
NO PC stated by you nor OS running on it.
why not ask the maker for help,
they will ask the same silly questions, like what exact model of scanner, number model, and what OS device , windows? android ,?
https://www.waspbarcode.com/barcode-scanners
My Wasp wws-800 works while
your wws800 should have come with two batteries. One goes in the reception base and one goes in the scanner itself. You should allow for four to 6 hours to fully charge. When charged, scan the setup barcode on the bottom of the reception base and then the BASE code. This will allow your scanner to create a connection with the base. Give it 5 secs or so, you should hear three beeps.
We have 2 WASP WWS500
Go to your blue tooth settings and delete it. After you delete it click on add blue tooth device. There is when it will ask you the 3 option's. The bottom Option is the one you want. (DON"T NEED A CODE OR DIDN"T COME WITH A CODE)
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
