20 Most Recent
Kyocera FS1370DN Laser Printer Questions & Answers
Error code: 0420:0010060?
This is refer to communication error between the printer and the extra drawer. If you power on the printer without an extra pf unit, does the printer power on?
Error f000
Main PWB is defective. So it has to be replaced.
Kyocera FS1370 reset
Press Menu button, then press the up arrow until you find the Adjust/Maintenance. Press the right arrow and search with the up arrow the Service choice. Then press the right button and search with the up or down arrow for Maintenance. Press the OK twice and the Install MK will disappear.
I have error code F00
Control PWB - Operation panel PWB communication error. You might have a bad operation panel or the connector to the panel may be loose.
communication error
KYOCERA FS 1370DN 7990 0088329
Empty the waste toner from the back side of the drum unit. Then remove and reinsert the waste toner sensor connector from the controller assy (main pwb).
When adding the printer on a mac, get the message
1. Remove the printer in System Preferences ' Print & Scan
2. Added the printer, again
3. Under the IP tab at the top of Add Printer, I chose the LPD option to the right of Protocol, instead of IPP
