20 Most Recent
Brother MFC9460CDN AllInOne Laser Printer Questions & Answers
I have tiny black dots
It sounds like the toner cartridge is spitting toner onto the drum. try another toner.
5/17/2017 7:17:25 PM •
Brother...
Answered
on May 17, 2017
Brother 9460 reset toner
Like most laser printers, the toner light comes on early. This gives you time to order new toner. I find it best, since it does not stop the printer from printing, just to have a toner on hand and when your toner is empty replace it. Since this is a mesurement inside the toner cartridge its self, there is no way to reset the warning (other than replace the cartridge).
2/13/2012 7:10:11 PM •
Brother...
Answered
on Feb 13, 2012
Broadcast fax
HelloThis broadcast fax service needs to first be set up by your telephone provider. you then give them a list of the numbers, then they give you a central number to send the fax to, which is then relayed to your list!!I hope this helpsRegardsGrant
11/14/2011 10:36:15 PM •
Brother...
Answered
on Nov 14, 2011
How can i tell ink
From the All programs menu on Windows, click the Status monitor icon. It will display the ink level.You may choose to configure the computer to display the icon on the task bar. A third way is to open the CC3 control center. Click the Machine configuration then ink level.
9/18/2011 11:42:41 AM •
Brother...
Answered
on Sep 18, 2011
Brothers MFC-9460cdn papaer tray cannot
Hi
Make sure the paper tray is installed properly. Re-install the paper tray. Hope this helps...please post back for further assistance.
Daniel
7/12/2011 11:25:51 AM •
Brother...
Answered
on Jul 12, 2011
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
