20 Most Recent
HTC Incredible S Questions & Answers
How do I Reinstal system in HTC incredible S ?
- Turn the phone off, or pull the battery if the system is unresponsive.
- While powering on the phone hold the volume down button along with the power button.
- It should boot to the bootloader(white background and black text) I don't remember exactly what number the option is for factory reset but it will be in the list(either factory reset or reset phone) use the Vol +/- keys to navigate up/down the list and use the power key to select.
Password barring
Should be your PIN or Mobile pass. Sometime it is 0000 or 12345. If that doesn't work you might need to reset your phone. The password is your SIM Pin it may Vary from the above i gave.
Lock key unlock automatic
Factory reset(but this will erase all your user data) unless your phone is rooted and have USB debugging enabled and know how to use ADB, then you can pull the gesture.key from the phone memory and use rev skills to brute force it.
Any unlock codes for the Htc Incredible S ? IMEI 355103040910625
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
