20 Most Recent
LG Optimus 3D Questions & Answers
Lg phone got wet and wont work
you got it went it wont work ever again to much water damage if you would of soaked it in rice after you dropped or whatever happened it would be fine
How do you connect lg optimus to samsung 3d tv via
Hi,Switch on the Mobile Internet from the settings->Wireless & Networks->Mobile Network->Data Enabled.[note: Connect the usb cable to the PC. Don't use it as Mass Storage.]Enable USB Tethering from the settings->Wireless & Networks->Tethering & Portable hotspot->USB Tethering.Now you can browse from PC via Optimus.Cheers,Mr.Maduraikaran.
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
