20 Most Recent Zebra Z4M+ Printer Questions & Answers
0answers
Z4M+ I/O Board
Be the first to answer 3/12/2014 4:57:23 AM • Zebra Z4M+... • Posted on Mar 12, 2014Be the first to answer
2answers
Zebra Z4M Plus
Is the length of the label correct on the configuration print out?
Else try t check if there isn't a feed or print adjust in the parameters
10/6/2009 3:36:19 AM • Zebra Z4M+... • Answered on Oct 06, 2009
Cannot set label length
Performing, Setting, and Troubleshooting Calibration Issues
This solution is useful for
  • Calibration: consistent positioning of the label and the print
Symptoms addressed by this solution include
  • Prints, then skips a label
  • Print is overlapping onto next label
  • Paper out error is occurring
  • Print position is drifting up and down on the labels
  • Labels stopping in random locations
Perform a manual calibration:
http://tinyurl.com/qyb9z3
Z4m + sensors
http://tinyurl.com/qeny9r
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
5/26/2009 5:48:16 PM • Zebra Z4M+... • Answered on May 26, 2009
Can you help me find a Windows 7 driver for my Zebra ZP-550 printer, please?
The Zebra ZP 550 will work with the GK 420t driver which is free for download at zebra.com. After installing it restart shiprush and your zebra printer will show up in your printer selection menu.
3/1/2021 7:02:56 AM • Zebra Z Office... • Answered on Mar 01, 2021
ZM600 printed barcodes will not scan
did you reset this printer to factory setting just visit this link http://blogs.scansource.com/zebra-zm600-how-to-reset-printer-to-factory-defaults/ if you have user guide plz flow that if you dont have it visit this link belowhttp://www.bluestarinc.com/techsupport/ZEBRA/Manuals/ZM400_600_UG.pdf
1/20/2014 2:49:21 PM • Zebra Z Office... • Answered on Jan 20, 2014
0answers
0answers
Zebra printer. How to print serial numbers with a code in sequence on it?
Question edited for clarity. Duplicate question deleted. Refresh page to see your question.
Zebra Printer Serial Number Structure
Zebra Support Community https://supportcommunity.zebra.com > article > Zebra-... May 9, 2019 - Zebra Printer Serial Number Structure ; XX - Product Reference (usually 2 but can be 3 or 4 digits) ; A - Place of manufacture ; YY - Year of ...
Generate serial number in zebra printer embed gene...
SAP Community https://community.sap.com > technology-q-a > qaq-p Apr 1, 2017 - How to generate serial number in zebra printer ('^XA^SN001,1,Y^FS^XZ') from a Smart form and also embed generated serial number in QR Code? We ...
How to print barcode with running number ZPL-II?
Stack Overflow https://stackoverflow.com > questions > how-to-print-... Dec 5, 2008 - Try changing the ^PQ2,0,1,N to ^PQ2,0,0,N . The value in in replicates field indicated that you wanted a duplicate serial number printed before ... 6 answers · 1 vote: Ripped from a ZPL II manual: ^AF^SN 0001, 1, Y^FS Define serialized field, starting value ... I want to print an incremental count on the top right corner of ... Jul 14, 2020 C# - Printed serial numbers using Zebra printer is not scanning Jul 20, 2016 Zebra ZPL code Repeat label X times - Stack Overflow Aug 10, 2017 Create unique serial with ZPL and RFID - Stack Overflow Aug 21, 2023 More results from stackoverflow.com ..
2/15/2024 7:16:44 PM • Zebra Office... • Answered on Feb 15, 2024
Zebra GX420t Label Printer wont calibrate?
It appears to be a well documented issue. Try the Zebra Support Forum. https://www.google.com/search?q=zebra+gx430T+wont+calibrate ..
12/15/2023 1:55:40 AM • Zebra Office... • Answered on Dec 15, 2023
2answers
My Zebra P120i will no longer print correctly
8/9/2023 6:56:58 PM • Zebra Office... • Answered on Aug 09, 2023
Zebra LP 2844 printing off center
If your Zebra LP 2844 printer is experiencing shifting or off-center printing, there are a few possible causes and troubleshooting steps you can try:
  1. Check print settings: Ensure that the print settings on your computer or label design software are correctly configured for the label size and layout you are using. Make sure the label dimensions and print margins are set accurately.
  2. Calibrate the printer: Perform a calibration on the printer to ensure it is properly aligned. To calibrate the Zebra LP 2844, follow these steps: a. Turn off the printer. b. Hold down the feed button. c. While holding the feed button, turn on the printer. d. Release the feed button once the green status light begins to flash. e. The printer will feed labels and automatically adjust the label alignment. f. Once the printer stops feeding labels, the calibration is complete.
  3. Adjust label position sensors: The LP 2844 has label position sensors that detect the start of each label. If these sensors are misaligned or dirty, it can cause shifting or off-center printing. Clean the sensors using a lint-free cloth and ensure they are properly aligned.
  4. Check label alignment: Ensure that the labels are loaded correctly and aligned properly in the printer. Make sure they are inserted straight and centered in the label guides.
  5. Inspect the print head: Check the print head for any debris, adhesive residue, or damage. Clean the print head with isopropyl alcohol and a cotton swab if necessary. A dirty or damaged print head can affect print quality and alignment.
  6. Update or reinstall printer drivers: Ensure that you have the latest printer drivers installed on your computer. If the drivers are outdated or corrupted, it can cause printing issues. Visit the Zebra website and download the appropriate drivers for your LP 2844 model.
  7. Test with different labels or ribbons: If the problem persists, try using different labels or ribbons. Sometimes, the issue could be related to the specific media being used.
7/2/2023 2:57:18 PM • Zebra Office... • Answered on Jul 02, 2023
I have a Zebra series 1 that keeps throwing a mecanical error after printer the first pass yellow. It also seems like it is checking the ribbon. When ever I open the card reservior lid.
One possible reason for this issue could be a problem with the printer's ribbon sensor. The ribbon sensor is responsible for detecting the presence of a ribbon and ensuring that it is properly aligned. If the sensor is not functioning correctly, it may cause the printer to throw a mechanical error and check the ribbon whenever the card reservoir lid is opened. Another possible cause of this issue could be a problem with the printer's motor or drive system. If there is an issue with these components, it may cause the printer to stall or throw an error message when attempting to print. To resolve this issue, it may be necessary to perform some troubleshooting steps. First, try cleaning the printer's sensors and rollers to ensure that they are free from debris or dust. Additionally, check to make sure that the ribbon is properly loaded and aligned in the printer. If these steps do not resolve the issue, it may be necessary to contact Zebra technical support for further assistance.
6/21/2023 7:49:01 PM • Zebra Office... • Answered on Jun 21, 2023
2answers
Zebra ZP 450 CTP suddenly printing wrong. Labels are scrunched up and only on top half of page
Hi, Please use your manual to follow the initial set of instructions that you used to setup label printing on your Zebra device. Then, you can run a few test prints to make sure that everything is working properly. Otherwise, you might need a factory reset. Thank you.
3/6/2023 5:48:28 PM • Zebra Office... • Answered on Mar 06, 2023
Popular Tags
6 questions posted
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Z Zebra
  • Z Zebra
Most Popular Question
zebra z4m plus
  • Office Equipment & Supplies
