20 Most Recent Lucent DSLPipe Bridge/Router Questions & Answers
click on start and click on run
on run open box type in cmd and hit enter
black window will open, type in ipconfig then click on enter then look for the default gateway address, that;s the ip of your router
dont 4get to rate solution
Lucent DSLPipe... | Answered on Sep 05, 2018
We need to know which Lucent and which voicemail system you have. When you dial into voicemail, what does the nice lady say? Welcome to......?????
Lucent DSLPipe... | Answered on Jun 04, 2009
Identifying Your Router's IP Address
You should have now received an IP address from your router. To view your IP address information do these two steps:
  1. Start > Run then type CMD then press Enter.
  2. Then in the command prompt type ipconfig /all
If you see your network interface with a list of IP addresses(should not be all 0.0.0.0's or 169.* addresses). If you got an IPstarting with 192.168.* or 10.* you are doing great! If not, verifyconnections or reboot computer. Observe the Gateway IP Address. This is the router's IP address. It may be one of the following, test in your Web browser:
http://192.168.1.1 or http://192.168.0.1 or http://192.168.0.50 or http://10.0.0.1
Once you see a login prompt, you need to log in with the default routerlogin. Usually they are a combination of "admin" and no password or"admin" for the password and no username " or "admin" for username and"password" for the password. Alernatively, you can search Google withyour model number and it should yield you some useful information onyour router including the default login/password.
Then when you are inside it, you should go to the LAN section andenable DHCP (if it already isn't). For security you may limit theamount of addresses to the number of computers (you don't have 254computers, so why allow 254 computers addresses?). For example, I allow3 IP addresses on my network to be issued, since I have a NAS, Laptopand a Desktop.
Lucent DSLPipe... | Answered on Apr 12, 2009
Rather then trying to hack the password, you are probably better off just resetting the router back to factory defaults, and starting fresh. You did say you had to reset the connection IP and speed.
Your second choice is to replace the router.
Lucent DSLPipe... | Answered on Feb 02, 2009
The driver will be on the manufactures web site. I doubt XP is still supported.
Lucent Computers... | Answered on Feb 24, 2018
Definition of: EGP
(1) (Exterior Gateway Protocol) A broad category of routing protocols that are designed to span different autonomous systems. Contrast with IGP.
(2) (Exterior Gateway Protocol) The original exterior gateway routing protocol (see above), which has been widely used in the U.S. Data Defense Network (DDN) and National Science Foundation Network (NSFNet). EGP is a distance vector protocol that uses polling to retrieve routing information. EGP has been superseded by BGP. See BGP and routing protoco
lhttp://www.pcmag.com/encyclopedia_term/0,2542,t=routing+protocol&i=50648,00.asp
ATP - AppleTalk Transaction Protocol provides a Transport Layer connection between computers. This protocol guarantees reliability by directing the transaction process and binding the request and response. Works at the OSI network model transport layer. Part of the AppleTalk suite of protocols. ( for Mack ...and aple device )
pseudo-device stf
DESCRIPTION
The stf interface supports ``6to4'' IPv6 in IPv4 encapsulation. It can tunnel IPv6 traffic over IPv4,
as specified in RFC3056.
For ordinary nodes in 6to4 site, you do not need stf interface. The stf interface is necessary for
site border router (called ``6to4 router'' in the specification).
Lucent Computers... | Answered on Oct 09, 2009
Make sure you are not using Perfect Forwarding Secrecy
Lucent Computers... | Answered on Aug 23, 2009
Lucent 7 cabling *probably* refers to level 7 Lucent cable. It's old!! There are two issues in the question of, "What is Lucent 7 cable?" Here's the history: Lucent was a division spun off by AT&T back in the mid 1990's. Then Lucent actually spun off Avaya and sent their structured cabling business with it (they had named the cabling brand "Systimax" by that time. CommScope bought Avaya back in 2004, so Lucent's Systimax brand of cabling is 2 generations out dated. It's still probably okay, but not worth today's money for new Systimax products made by CommScope.
Now for the 7 issue: there was no talk of category 7 (cat 7) back when Lucent was making cable, but Anixter, a data cable distributor, rates cabling with their own proprietary system called "Levels". Therefore, Level 7 cabling is an Anixter measure and many people have bought from Anixter long enough that they ask for level 7 [brand whatever] cable.
Use it if it's low cost. Otherwise, don't let someone sell Lucent branded-cable as the same as today's cable. There were version upgrades since then. The print on the cable jacket will say 1071C or 2071C or something like that. Today, they are on version E, not C.
Hope it's kind of clear. My guess is the cable is about 10 years old, although some data folks are stuck in their ways and still refer to today's Systimax cable as Lucent cable.
Lucent Computers... | Answered on Jun 01, 2009
Android app Ko Mobile phone me computer Se Kaise Install karte hai.Sabhi android user Google play store Ka use karte hai aur play store Se Hi Android apps or games Ko Download karte hai.Lekin Agar aapko Android phone Ke play store Se app download Karna pasand nahi karte hai ya aap jab computer ya laptop Ka use karte hai us samay aapko kisi Android apps Install Karne Ki jarurat hoti hai.To aap apne computer Se Android apps Ko directly Install kar sakte hai.Mere kahne Ka matlav ye hai Ki aap play store Ka use apne computer par karke Android apps Download or install kar sakte hai.Mai aapko kuchh tips de raha hu jiski help Se aap kisi bhi Android app Ko PC Se apne mobile phone me Install kar sakte hai.To friends Agar aap apne PC Se Mobile Me Android app Install karna chahte hai,to aap meri is post Ko puri tarah read Kare Ki computer Se Android app Ko Mobile Ya Phone Me Kaise Chalaye or install Kare.
Android Apps Ko Mobile Phone Me Computer / Laptop Se Kaise Install Kare ?
Android apps Ko Android phone me computer ya laptop Se bahut Hi asani Se Install kar sakte hai.Mai aapko Android apps or games Ko Computer Se Mobile Me Install Karne Ka step bata raha hu.
Note - Android apps and games Ko Computer me Install Karne Se pahle apne phone Ko internet Se connect kar de,warna sayad jab aap apne phone Ko internet Se connect karebge tab aapje phone me Android apps or games Install ho jayega.
1. Sabse pahle aap apne computer me Google play storeopen Kare.
2. Phir aap same Google account Se login Kare.
3. Phir aap apna app find karke Install par click Kare.
4. Apne device Ka name and model number type Kare aur Install par click Kare.
5. Phir aap apne phone Ke notification bar Ko slide karke dekhe aapka app installing progress start ho chuka hai.
* Computer Me Android Apps Or Games Kaise Install Kare Or Chalaye
* Android Phone Se Computer Me Windows Kaise Install Kare
To dosto kuchh is tarah Se aap bahut Hi asani ke sath kisi bhi Android app Ko apne computer Se apne phone me Install kar sakte hai.
Computers &... | Answered 5 hours ago
Put the USB into a computer and verify it works in there. It sounds as if the file system has become corrupted when you added the last batch of songs. If so, just reformat it on the computer and reload the music in one batch.
Computers &... | Answered 8 hours ago
then perhaps you need to check with NVC . FIXYA can not get one for you
Computers &... | Answered 14 hours ago
Lucent DSLPipe Bridge/Router Logo
5 questions posted
Top Lucent Computers & Internet Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Gaurav Kr
Gaurav Kr
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lucent Computers & Internet
Most Popular Question
find router ip port forwarding
  • Computers & Internet
