20 Most Recent
Phonic Powerpod 820 200w 8 Channel Powered Mixer Questions & Answers
Turning my Phonic PowerPod7 into a home stereo
To turn your Phonic PowerPod 7 into a home stereo system, you will need to make some additions and connections to the existing setup. Here are the steps you can follow:
- Connect speakers: You will need to connect a pair of passive speakers to your PowerPod 7. You can do this by connecting the speaker cables from the speakers to the "Speaker Outputs" on the back of the PowerPod 7.
- Add a source: The PowerPod 7 has two channels, so you can connect a stereo source such as a CD player, turntable, or music streamer. Connect the left and right audio outputs of the source to the corresponding inputs on the PowerPod 7.
- Connect to power: Make sure to plug the PowerPod 7 into a wall outlet to power it on.
- Adjust the volume: Use the volume knob on the PowerPod 7 to adjust the overall volume of the system.
- Tune the sound: If desired, you can adjust the tone controls on the PowerPod 7 to tailor the sound to your preferences.
With these steps, you should have a functional home stereo system using your Phonic PowerPod 7.
2/13/2023 11:57:30 AM •
Phonic Music
Answered
on Feb 13, 2023
Purchased a Phonic 740plus. Can't get the 16 channel effects to work. Manual is vague in this area. I seem to have everything set properly but it doesn't work. Does this need to go out to another amp?
Getting Started
1. Turn all power off on the Powerpod mixer. To ensure this, the AC cable should not be connected to the unit. 2. All faders and level controls should be set at the lowest level to ensure no sound is inadvertently sent through the outputs when the device is switched on. All levels should be altered to acceptable degrees after the device is turned on. 3. Plug all necessary instruments and equipment into the device's various inputs as required. This may include line signal devices, as well as microphones and/or guitars, keyboards, etc. 4. Plug any necessary equipment into the device's various outputs. This could include speakers, monitors, signal processors, and/ or recording devices. NB. No devices other than speakers should be connected to the power amp outputs. Plugging inappropriate devices into the mixer will likely cause damage to the device. Also, guitar cables should not be used to connect amplifiers to speakers. 5. Plug the supplied AC cable into the AC inlet on the back of the device, ensuring local voltage level is identical to that selected by the Voltage Selector on the rear of your device. 6. Plug the supplied AC cable into a power outlet of a suitable voltage. 7. Turn the power switch on.
5/5/2021 12:50:53 AM •
Phonic Music
Answered
on May 05, 2021
Asio driver download
I use a 16 bit 44.1/48k phonic interface with ASIO4ALL, just search this on the net and down load.
11/1/2013 5:33:20 PM •
Phonic Music
Answered
on Nov 01, 2013
How many volt , ac.or dc. for power supply phonic MM1202 mixer
I tells the power supply model numbers on the back of the unit above the power connector plug. It doesn't tell the specs as of how many amps but does describe several voltages of AC it would work on and also gives several model numbers of the correct power units that are sufficient. If you don't use one the recommended units, it could malfunction and give extra static noises caused by improper filtering of the power. It shows on page 8 of this manual:http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=39&ved=0CHkQFjAIOB4&url=http%3A%2F%2Fsoundhouse.co.kr%2Fsoundh%2Fcatalog%2FPHONIC%2Fmixer%2FM-U-1-2-0-2_1-2-0-2-X_om.pdf&ei=QPdbUaX3K4zA9gS11IFY&usg=AFQjCNGoMutp27pESma_-Mw36637hlmHOA&sig2=8J0-4rb6sHlit-OdKlIFbgI hope this helps you.
4/3/2013 9:46:16 AM •
Phonic Music
Answered
on Apr 03, 2013
