20 Most Recent
HEWLETT-PACKARD LaserJet M1319F All-In-One Laser Printer Questions & Answers
Amber light is on
Unplug the power cord and the USB cable from the rear of your printer. Wait one (1) minute. Plug the power cord back in. Plug the USB cable back in. Re-start your computer. In most cases, this will solve the problem. Good luck.
Hp laserjet 5100n
Go to the hp.com site and search for said driver. Sometimes they do not update their drivers for older machines, but I am not familiar with this one. Good luck. Once a year Staples will have a special where one can trade in an old machine for a discount on a new HP.
HP Laser printer USB connector broken
What model? Connector on the outside or on the mainboard? If on the mainboard, replace it. If on the front, you should be able to just replace the connector cable and/or mounting.
Cannot receive fax
make sure you have a phone line plugged in correctly (into the in plug) and set the printer / fax to recieve auto. Do not pick up the phone while recieving the fax, If thei does not work, check your setting in the software.
Hp f4435
I'm assuming you have the correct drivers loaded and correctly configured.
Set power switch to off.
Unplug it for 1 minute.
Plug it back in.
Turn it on.
If it still won't work, I suggest replacing the power supply.
If it still won't work, I suggest you replace it.
