20 Most Recent
Washburn HB30 Semi Hollowbody Electric Guitar Questions & Answers
Sound cuts out washburn hb30
Nice looking instrument. First try a different cord if you have not already. The plugs can break inside, even moulded plugs.If that does not work then a possibility is that the outlet socket on the guitar has an internal break, either a wire or a contact leaf.If it is secured by a small plate and 2 screws (probably not on this model), remove these and pull the socket assembly out carefully, and look for any loose wires or broken bits.If the socket is secured in the body just by a locknut, it may come loose inside the body. This photo looks like it does just that
http://media.photobucket.com/image/washburn+hb30+/guitaroutlet-mercadolibre/washburnHB30.jpgOnce the socket assembly is floating around inside, you have to fish it over to the f-hole, to take a look at it. You should be able to push it there with a thin rod.If it is broken, you may be able to wiggle it outside for repair.Then the problem is to pull it back and replace it!! A thin rod with a little hook on the end may help.
I have a Washburn WCD18DCE guitar and I need to change the battery
Depending on the year, it could be a couple different places. There could be a little battery compartment on the outside body of the guitar. Sometimes they are separate from the other electronic controls. Sometimes that are part of the controls or even part of the guitar jack. But if it is on the outside of the body, it will have a little door that pops open when you push a tab. You just have to look and see if there is a little rectangular door. If you don't have a little door, then it is likely tucked inside the guitar, just inside the sound hole. If it is in there, then you will probably see a little cloth pouch with wires coming out. Thats where the 9v battery is kept and plugged in. It's usually held to the body with velcro.
Washburn pro x series wiring diagram pictures
You can try looking for a wiring diagram for your Washburn Pro X series guitar at the following places:
- The Washburn website: The manufacturer's website may have wiring diagrams available for download for their guitars.
- Online forums: Online guitar forums such as the Washburn Forum (https://www.washburn.com/forums/) may have wiring diagrams posted by other users, or you can post a request for one
- Luthier: A Luthier or guitar repair specialist may be able to provide you with a wiring diagram for your guitar.
- Online guitar parts retailers: Some online guitar parts retailers may have wiring diagrams available for download on their websites.
Please note that the wiring diagram may vary depending on the specific model and year of your Washburn Pro X series guitar. It's best to check the wiring diagram for your specific guitar model to ensure that it is accurate.
Serial Washburn mirage pro serial is 833864
How value ?
Where it made ?
Thanks
Your best bet is to take it into a reputable music store that sells everything from custom made high
end modell guitars, electric, acoustic/acoustic electric to classical. Get an appraisal by a professional DO NOT GO TO A PAWN SHOP OR ANY BUY AND SELL ONLINE SITES (Craigslist, Kijiji, eBay etc.) They will either low ball you to try and rip you off or won't have a clue what they're talking about. Long & McQuade has always been solid for me and there's this really nice high end music store in my city that are proffessional musicians (university degrees up the the Ying/Yang)
I doubt this is much help but it's what I would do. The other most obvious is to lookup the Washburn website and most likely they'll have online help via I.M.
