20 Most Recent
NetGear DG834 Router Questions & Answers
How do I get to the WEBSITE //198.168.0.1 ?
you need to have your router connected to your computer (ethernet) and once this is done you enter the 192.168.0.1 into your web browser i.e Internet Explorer, Mozilla, etc this should open that for you, its the standard IP address for your router, this will allow you to log onto the router and change settings, etc.
My netgear dg834g keeps loosing the internet
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default. Change to anotherchannel.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedropouts and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
I have just install a
Well you do not have to worry about the flashing internet light as it is normal for the router to have flashing internet light when it is communicating with the service provider.
Please revert for any further clarification on the same.
Regards
Anand
Net gear N 150 adsl+modem
If the light is out or red, then you are not getting any power or you might have a power supply problem. In most cases a red light on the modem or router indicates hardware problems. You can purchase a new power supply for it. It could be the modem is bad, the question is, do you still have an internet connection? If so, it is probably a faulty light or power sensor, and the cost of a new modem or power supply may not be worth the effort. If you do not have internet connectivity, then you have a totally seperate issue and then you should call your ISP and ask them about your internet connection. It could be your internet is down or they have line problems. It may also be that you are plugged in to a multi outlet strip and you should try plugging it in directly to the wall.
I hope this was useful and please comment if this was helpful to you.
Router - CVG824G
hop do i
Thank you for using FixYa
1. Set a static IP address on the 360
2. Set up port forwarding
3. Turn on UPnP
4. Enable the DMZ
Blue lights turn off
Well I know this annoying thing too well.On the top of the device is what could best be described as a blue police light. As soon as power is applied to the DG834PN, this light begins flashing in a rotating motion. Fortunately you can turn this feature off before it becomes too annoying or causes a migraine. You will need to access the product's configuration option, select the maintenance section and alter the settings that come under Dome LED Control. The flashing light can be set to on, off or as per schedule.
This should resolve your issue.
Reboot
Well, this seems to be a hardware issue with unit. Please request NETGEAR for a replacement if the unit is under warranty. Contact them at http://my.netgear.com
Regards
Anand
I use AOL as my ISP, with British Telecom
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
I can't find my password wep
You MUST have generated, and recorded that, when setting up the Router for the FIRST time, IF you do NOT have it recorded, than you MUST set up the router again, this time, saving the KEY, now as it is 128 number number, it's not feasible, to write it down, so when you are Generating the KEY, you copy/paste it to a notepad document, save that and put it on a USB drive, now you take said USB Drive, to any "Client" PC's and copy/paste in into the required "Field" when asked, at login to network. All is explained in the manual.
kbserver.netgear.com/pdf/dg834_dg834b_ref_manual_03Jun05.pdf
Manual link above.
Local area connection unplugged
Hi
Thanks
for using FixYa. It means that there is an issue with the connection provided
by the service provider and you’ll need to contact him to get it started and
also check that the connection to computer is fine. To diagnose and repair just
right click on the connection icon in the bottom right corner and then click on
diagnose and repair option. It’ll also resolve the issue. Please
do accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
Wireless light on router does not light up
there is a rest hole on the back, with router off push a straightened paperclip in and hold it for more than 10 seconds, this should reset to factory settings (I had to do this more than once) then you can connect via cable and access from your browser and re set your details.
