20 Most Recent Peavey Electronics Peavey PV10 Mixer Questions & Answers
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
Peavey... | Answered on Dec 20, 2013
If you have any cables from the effects inserts section of the board inserted, disconnect them. Check ALL sends levels. Check effects processor for L.E.D. signal. .(Assuming you are using the internal effects.)
Here is an excerpt form the manual:
https://assets.peavey.com/literature/manuals/80301359.pdf
Peavey Music | Answered on Oct 23, 2019
Try to find a new board. Trust me, you are not going to fix it - there is a reason the traces and board are showing burn marks. Either scrap it or just buy another one. If you toss it cut the power cord off next to the chassis.
Peavey Music | Answered on Sep 30, 2019
Have it looked at - there is probably some chip that is burned out in the output section.
if the wires are sodered on to yhe ends of the fuse you can carefully cut them right at the fuse but i would hold my sodering tip on the weld and pull the wire off when the solder melts. Unfortunatly you would have to solder a new fuse back in being realy,really carefull about how long u leave the heat on as it could cook the fuse Sounds like a job for a repairman as you dont want to be frying anything else or altering a good amp and if they screw it up they have to take care of it. please let me know how it goes,im curious.
Peavey Music | Answered on Sep 27, 2019
It is possible that you have issues with caps in the power supply...I would check those first...and you can get the schematics from Peavey....
Contact Peavey...They have no problem in releasing technical documentation....I always get info from Peavey...
Peavey Music | Answered on Sep 24, 2019
Hi Elijah, check that you have assigned the channels to a SubMaster to the Master and that they are not in MUTE
Hola Elijah, controla que tengas asignado los canales a un SubMaster al Master y que no se encuentren en MUTE https://peavey.com/products/index.cfm/item/666/118299
Peavey Music | Answered on Sep 04, 2019
If you are a competent electronics engineer with service information and access to Peavey spares, they are an easy fix otherwise they will not be easy.
Peavey Music | Answered on Aug 14, 2019
There are a lot of possible problem areas it could be. I would first check that the speaker is working correctly. If so, I'd clean all jacks and pots. If that doesn't do it, it'll be time to take it to the shop.
Peavey Music | Answered on Jun 22, 2019
I would think you can if the amp is rated for 4 ohms but the 4 ohm might be loader then the 8 ohm because it will get more power.
Peavey Music | Answered on Jun 09, 2019
Hello John, the fuse is in the power input of Tu Peavey
If you notice, on the rear panel, where the power cord is plugged in, up on the same connector, you will see a horizontal cover that can be removed by placing a tip on the underside of this cover and pulling outwards, it will come out a plastic element, which holds the fuse, this element has an intermediate space where another spare fuse can be housed
I hope my comment has been useful and you can take out the fuse
Keep in mind that if you blow the fuse, because I pass, check the cables and speaker connectors, that do not have any short circuit
Greetings Franco Dosil
Hola John, el fusible se encuentra en la entrada de energ?a de Tu Peavey
Si te fijas, en el panel trasero, donde va enchufado el cable de corriente, arriba en el mismo conector, vas a ver una tapa horizontal que se puede sacar poniendo una punta del lado de abajo de esta tapa y haciendo fuerza hacia afuera, saldr? un elemento pl?stico, que sostiene al fusible, este elemento tiene un espacio intermedio donde se puede alojar otro fusible de repuesto
Espero que te haya servido mi comentario y puedas sacar el fusible
Ten en cuenta que si se quemo el fusible, porque paso,revisa los cables y los conectores de parlante, que no tengan ning?n cortocircuito
Saludos Franco Dosil
https://www.google.com/url?sa=i&source=images&cd=&ved=2ahUKEwiUpJWv4bDiAhUTIrkGHXfyDoQQjRx6BAgBEAU&url=https%3A%2F%2Fwww.tme.eu%2Fhtml%2FES%2Fconectores-machos-iec-con-proteccion-de-fusible-para-panel-schurter%2Framka_3250_ES_pelny.html&psig=AOvVaw3u39E87rodMysi11CwjaR6&ust=1558670267837577
Peavey Music | Answered on May 23, 2019
Peavey Electronics Peavey PV10 Mixer Logo
1 questions posted
Top Peavey Music Experts
Michial Gueffroy
PNiss
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
want know connect powered subwoofer
  • Music
