Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
- Username = admin
- Password = password
- For older devices, password = 1234
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is
admin and the password is either
password or
1234. Try these before resetting the router.)
- Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
- Release the button.
- Wait for the router to reboot.
- Log in with the default password.
If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
- Unplug the router's power.
- Press and hold the reset button. While the button is held down, reconnect router's power.
- Continue to hold the reset button for 20 seconds after reconnecting the power.
Or you will need to update the firmware to rest the router.
