20 Most Recent
Lexicon I ONIX U42S 4x2 USB 2.0 DESKTOP RECORDING STUDIO Questions & Answers
I have an I-Onix u42s
Probably the sound and devices settings in Windows control panel have been clobbered back to the computer audio instead of the Lexicon. Check the device defaults in "Audio" and "voice" tabs in the "sound and devices" in the Windows control panel.
I have problems with my
Dynamic mics such as the Shure SM58 require the input trim levels to be almost or at MAX setting... this is normal. Are you aware there are counterfeit SM58's being sold from sources on Ebay? Search Gooogle for info about this and how to tell the difference.
I don't know what the latentcy is since you have not told us what you are attempting or where you are seeing this. If you are converting (recording) and playing back at same time there will be a latentcy because unit has to convert, put in memory then convert the other direction. The latency from this is NORMAL. If the unit has a MONITOR function, it can just echo the input signal without converting while recording to avoid latency.
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
