20 Most Recent
JVC Mobile Mini Note PC MP-XP3210 PC Notebook Questions & Answers
My battery on my JVC
How long have you had the battery?
The average life of a battery if charged everytime the laptop is used can be as low as 12 months.
Try a replacement battery if this one is exhausted.
How do I rest my Jvc LT-55N776 without a remote
You can still reset your TV using alternative methods. Let's explore a few options:
Soft Reset:
A soft reset won't erase your TV's applications or settings. It's a simple way to restore the TV to its default state.
Here's how to perform a soft reset:
Unplug your JVC TV from the power source.
Leave it unplugged for 30 seconds.
Re-insert the TV's power cord into the power outlet.
Turn on your TV and check if it's functioning normally.
Hard Reset:
If the soft reset doesn't solve the issue, a hard reset might be necessary. Keep in mind that this will erase your TV's previous applications and settings.
Follow these steps for a hard reset:
Unplug your JVC TV's power cord from the electrical outlet.
Wait for 60 seconds.
Plug the cord back into the power source and re-plug your TV.
Locate the control panel on your JVC TV (usually on the side or back).
Press and hold the Volume Down and Menu buttons on the control panel for 10 seconds.
While still holding those buttons, press the TV's power button and continue holding it.
Release all buttons.
Turn on your TV and check if the issue persists.
Mobile App Reset:
Download the Google TV app on your Android or iOS device.
Use the app to reset your JVC TV to factory defaults.
Wireless Keyboard Reset:
Connect a wireless keyboard to your JVC TV.
Use the keyboard's touchpad control to navigate and perform a reset.
Contact Customer Care:
Reach out to JVC Customer Care and follow their instructions for resetting the TV.
Remember, these methods should help you get your TV back to its default settings even without a remote. If all else fails, consider getting a new remote control to make future adjustments easier.
Can't set jvc monitor for optelec 500 viewer ...
.......... for vision impaired.
wow a real JVC computer question, not TV or what not wrong.
cheers to that.
Ok
no monitor told at all, and nobody can guess what that is.
and no 2 the same from 1979 to now vast models made.
all have unique settings and features;
and
Optelec US Clearview 500 6017C CRT Low Vision Magnifier??????
is the JVC A CRT RELIC MONITOR OVER 22 YEARS OLD
THE READ OF ANY MONITOR 99% HAVE LABLE ON THE REAR
WITH MODELS STATED
oK, NOW I GO TO CRUDE GENERIC ANSWERS.
push OSD button
then find reset and push that.
end.
my guess 22 year old PC?? non told.
22 year old monitor?/
and is VGA connected
and if yes the OSD settings have horz and vertical positioning and centering and SIZE of raster.
be easy to mess all that up as kids love to do for 40years.
but newer PC with DVI , HDMI or DP connections vastly less to get wrong, due to smarter digital controls
sorry no comment on Optelic, not sure how it works, and rare.
more modern PCs have build in zoom features
windows 10 and screens can be huge too and zoomed, even a TV set 55" +up works ok on a PCs, (not gaming but all else ok)
also new PC can read the screen to you, text to speach
just a few ideas there. good luck
JVC Monitor will not sync anymore with our sky
NO PC TOLD or OS
No monitor told maker yes MODEL no, and 1979 to now made, vast.
what does SKY mean?
no sync means PC is dead or video card or GPU chip is dead.
no PC told
a monitor can be tested on a 2nd good pC to see if
PC 1 is bad,or the monitor.
easy as eating cherry pie, a test that cuts he problem in 1/.2 .
other causes.
- PC is dead.
- cable not told bad (VGA? what)
- cable pins bent on either end.
- both ends plugged in wrong. to PC or mon.
- monitor OSd set to wrong video port, making it dead.
- if pC has PCI video card the monitor cable must go there.
- the monitor is not dead it told you no_sync and means inputs dead.
JVC DLA-X70RBE projector.
HDMI 1 and HDMI 2 inputs do not work.
buy the service manual from JVC
otherwise it's pure guessing all that. (see my tests)
you say that chip inside the PROJ, was changed? where?
did the projector ever work before (your eyes only)/??????
history matters, for sure bought it dead
does PROJ fail on 2nd good PC, that is test #1 why skip that?
get hit by lightening? that be reason to replace chips , not guessing.
what of last person flash upgraded the firmware and bricked it.
well no history told so I know nothing here
is PC mobo HDMI port
or is untold PC have HDMI video card,(must be used only if here)
or using vast lame HDMI adapters.
is this uSA projector or EU? or what?
is the lamp dead?
oMG does the VGA in port work stated in the manual i just read.
did you full y test the PCs HDMI port first using TV or PC with HDMI/?? seems that be wise.
then try 2nd good PC to test any projector
i can not watch you connect things wrong sure can not.
im blind in a text box even post photos.
of connections all.
and help goes x100 more easy, no kidding. help the helper,
I can't burn 2Gb even though my DVD is 4,7 Gb
The size of the file in MB. does not equal what is burned onto the disk. 4 x 600 = 2400 MB. but what is burned to the disk is usually more than what the file size equals. Try using a dual-layer blank disk and see what happens.
JVC 700X handycam digital video camera driver
Drivernya dah di Install belum gan ?kabel Koneksi dari Handycam ke PC pastikan dalam kondisi bagus/ga patah didalam kabel.biasanya kalo kondisi kabel bagus,bakalan keluar keterangan Found new Hardware > Unknow Device.atau pastikan aja dari Computer Management > Device Manager.(Click Kanan my Computer > pilih MANAGE).Kalo ada Tanda Tanya Kuning berarti Kabel Kondisi bagus.Trus kalo Driver belum di install,ente bisa download dari :5 Driver Finder (Online) :1. http://www.all-driver.com- Search for all aviable Driver2. http://devid.info- Search Driver From Hardware ID (you can See Hardware ID from :Computer Management > Device Manager > Propeties hardware you've Need the driver > Details3. http://www.driverguide.com- Search Driver by Model Name or number4. http://www.driverstock.com- Search Driver by type and the producer5. http://www.nodevice.com-Seacrh driver from Categories or CompaniesKalo manfaat ditunggu Cendolnya gan....
Cds play on all cd players but the ones i made on new computer do not why?
it all depends on the CD's your using. some CD's will not play on some players. try DVD-R blank disc, this may make a difference. try one to see ! I ran into the same problem a while ago! it depends on the player itself, DVD-R 4.7GB data 16xspeed. this should work if player is compatable with it.
