20 Most Recent Sentry Fire Safe 14-gun Safe Combination Hgloss Gs1459c Questions & Answers
How do I open a waterproof fireproof small sentry safe if the lock doesn't fully unlock
Easy and fast to open with a rare earth puck magnet
Opening a sentry electronic safe with a magnet and ...
Reddit · r/lockpicking 10+ comments · 6 years ago It's not just locks. Arguably one of the most popular and ubiquitous pieces of access control hardware is vulnerable to this same attack. Can you open a mechanical dial lock with a rare earth magnet?? Jul 2, 2016 Recommendation on size of magnet for cheap Sentry Safe ... Feb 20, 2018 Does a magnet still work on sentry safe? : r/safecracking - Reddit Jun 12, 2021 YSK: Most electronic safes can be opened very easily. - Reddit Mar 14, 2022 More results from www.reddit.com
Open Electronic Sentry Safe in Seconds with Rare Earth ...
Mr Locksmith Training https://www.mrlocksmithtraining.com > open-electronic-... Open Electronic Sentry Safe in Seconds with Rare Earth Magnet · Dimensions: 3? dia. x 1? thick · Tolerance">Tolerances: ±0.004? x ±0.004? · Material: NdFeB, ...
3 Ways to Pick a Sentry Safe Lock
wikiHow https://www.wikihow.com > ... > Lock Picking Grasp the handle and wiggle the magnet until the safe opens. Hold the magnet at the top left corner with one hand and the safe's handle with the other. Slide ... ..
3/12/2024 5:13:40 PM • Sentry Home... • Answered on Mar 12, 2024
I need instructions for my sentry 1330
https://cdn.masterlock.com/sentrysafe/resources/pdf/manuals/Sentry-SLS-Old-Models-Instructions.pdf That is what downloads when you enter 1330 as the model number. If you Google sentry 1330 instructions, the google results pop up some questions and answers that may be of interest with you click the carrats beside the questions.
3/5/2024 7:17:04 PM • Sentry Home... • Answered on Mar 05, 2024
What are the cubic inches for my Sentry Valueguard 1330 safe #1623580?
Volume (in³): 2160 cubic inches If you want to measure the cubic inches of a container, measure the length, width, and depth in inches. Then multiply those numbers by each other. For example, if your container is 5 inches long, 3.5 inches wide, and 7 inches deep, your calculation will look this: 5 x 3.5 x 7 = 122.5 cubic inches. May 17, 2023 Cubic Inch Calculator https://www.homedit.com/calculators/cubic-inch-calculator/#:~:text=If%20you%20want%20to%20measure,x%207%20%3D%20122.5%20cubic%20inches Sentry Valueguard 1330 Safe Perfect for a home closet, office, etc... Outside dimensions: 22"x17"x17" Inside Dimensions: 14-3/4" deep 12" wide 15-1/4" tall Pic with water bottle is for size reference...
Safe - Sentry Valueguard 1330 for Sale in Clovis, CA - OfferUp
2/24/2024 10:37:04 PM • Sentry Home... • Answered on Feb 24, 2024
How can I change code to a sentry 6250 safe
What you have is one of there products. You need to go to the following web address they have an on line form you fill out and will provide u with an opening combination. https://www.sentrysafe.com/support/
1/24/2024 10:44:18 PM • Sentry Home... • Answered on Jan 24, 2024
My lock on my sentry 1100 safe was drilled out at the key hole. How do I get a new lock for it?
You just buy another one, they are 50 bucks new. Or contact Sentry Safe and see if they will sell you one. Or take it to a locksmith and they will order and fit one for 75 bucks.
SentrySafe® Official Site ' Gun Safes & Fire Safes
Sentry Safe https://www.sentrysafe.com SentrySafe offers a broad range of secure storage solutions to keep your valuables protected from unexpected perils, theft and more. View safes. ‎Safe Selector · ‎Fire & Waterproof Safe · ‎Check Your Electronic Fire Safe · ‎Contact Us To buy a new one. https://www.google.com/search?q=sentry+1100+safe ..
9/1/2023 4:39:46 PM • Sentry Home... • Answered on Sep 01, 2023
I have a sentry professional quality/ 6250 safe I have had it for over 20 years it's manual no key I can't remember combo and I no longer have manual.
You are pretty stuck with that scenario. With an electronic lock you can use a rare earth magnet to pull the locking bolt but with a manual dial safe, you can't do that. I can remember my business safe combination from 1987 to 2005. You can also write it down. Use a concrete saw or angle grinder and cut the back off it. ..
7/2/2023 3:32:10 AM • Sentry Home... • Answered on Jul 02, 2023
Sentry Safe 1610. I can't open safe 1610. No documents with it.
Question edited for clarity. Although this guy makes it look hard work, they will usually bounce open quicker that this. You can also bang the top with a rubber mallet, or use a rare earth puck magnet to pull the actuator bolt.
5/18/2023 9:04:20 PM • Sentry Home... • Answered on May 18, 2023
2answers
Sentry Supreme 5330 safe will not open
If your Sentry Supreme 5330 safe is not opening, there could be a few possible reasons why:
  1. Combination Error: If you are using a combination to open the safe, make sure that you are entering the correct combination. If you have forgotten the combination, you will need to contact Sentry Safe customer service to get assistance on how to recover or reset your combination.
  2. Dead Batteries: If you have an electronic lock on your safe, the batteries may be dead. Replace the batteries and try again.
  3. Jammed Bolts: The locking bolts may be jammed due to incorrect operation or a mechanical problem. Try tapping the safe door gently with a rubber mallet to loosen the bolts and then try to open it.
  4. Mechanical Malfunction: If the safe still does not open, there may be a mechanical malfunction. In this case, you will need to contact a professional safe technician to diagnose and repair the problem.
Note: If you have lost your key, you will need to contact Sentry Safe customer service to order a replacement key.
4/25/2023 10:00:45 PM • Sentry Home... • Answered on Apr 25, 2023
I HAVE A SENTRY SAFE 1250
pins are available at hardware stores
3/18/2023 12:36:33 AM • Sentry Home... • Answered on Mar 18, 2023
Sentry Safe 1250. How to change the combination please?
Safes with dials are a little more complicated. NEVER close the door after changing the combination. Practice the opening sequence with the door open. If you did it wrong, you can reset and try again https://www.google.com/search?q=Sentry+Safe+1250.+change+the+combination
3/13/2023 6:21:23 PM • Sentry Home... • Answered on Mar 13, 2023
Have a American Dynamics AD2089 keyboard for CCTV.
Try rebooting the whole system as that will reload the software for operating system and the drivers for the keyboard. https://www.google.com/search?q=american+dynamics+ad2089+keyboard+not+responding
1/1/2023 8:59:36 PM • Sentry Home... • Answered on Jan 01, 2023
How do I turn off the sound on my sentry safe lock box?
The sound does two things It lets you know you have done a positive button push. It beeps when the battery is low to alert you to change them and save you having to cut the back off the safe. It isn't programmable, snip the wire to the sounder, but it is likely hard soldered to the main board.
12/28/2022 12:31:11 AM • Sentry Home... • Answered on Dec 28, 2022
Have Sentry V330 U483070 HAVE last combo number and the key pleases help
no question --and notify sentry customer assistance or a locksmith when dealing with safes
12/27/2022 2:50:08 PM • Sentry Home... • Answered on Dec 27, 2022
How to open Sentry safe ms3817?
There are several possible reasons why your Sentry Safe MS3817 is not responding to the handle or new batteries. Here are some steps you can try to fix the problem:
  1. Check the batteries: Make sure the batteries are properly installed and not depleted. You may also want to try using a different set of batteries to see if the issue is with the batteries themselves.
  2. Check the battery contacts: Make sure the battery contacts are clean and free of any debris. You can clean the contacts with a soft cloth or toothbrush.
  3. Check the handle: Make sure the handle is not damaged or stuck. You may need to apply some lubricant to the handle to loosen it.
  4. Check the lock mechanism: Make sure the lock mechanism is not damaged or stuck. You may need to apply some lubricant to the lock mechanism to loosen it.
If none of these steps help, you may need to have the safe serviced by a professional. As for the factory code, it is recommended to contact Sentry Safe or the retailer where you purchased the safe for assistance. They may be able to provide you with the factory code or help you reset the safe.
12/21/2022 9:57:54 AM • Sentry Home... • Answered on Dec 21, 2022
Factory code for sentry safe combination SFaw123CU
limited info generic answer no [factory code] notify or go to sentry site other option locksmith
12/13/2022 1:16:57 AM • Sentry Home... • Answered on Dec 13, 2022
Changing the code on sentry safe csw3607
To change the code on a Sentry Safe CSW3607, follow these steps:
  1. Open the safe by entering the current code on the keypad.
  2. Press and hold the "*" button on the keypad for three seconds. This will put the safe in programming mode.
  3. Enter the current code on the keypad, followed by the new code you want to use.
  4. Press the "#" button to save the new code.
  5. Close the safe and test the new code to make sure it works.
It's important to note that the CSW3607 has a factory default code of "0000". If you have not changed the code from this default, you can simply enter the new code you want to use without going through the programming mode.
12/11/2022 5:22:51 AM • Sentry Home... • Answered on Dec 11, 2022
Sentry Fire Safe 14-gun Safe Combination Hgloss Gs1459c Logo
2 questions posted
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Sentry Home Security
Most Popular Question
lost combination sentry safe model
  • Home Security
