20 Most Recent
Scotsman Ice Machine, Cuber, 1825 lb. Unit, Head Only Questions & Answers
Cme 506 cubes too small
turn ice bridge thickness screw clockwise to thicken and counterclockwise to get thinner. Do not turn anymore than about 1/8 turn between freeze cycles. the adjustment screw is very finicky and requires patience in setting properly. the distance from the bridge thickness gauge to freeze platen is approximately 1/4 - 5/16 of an inch.
Can`t get scotsman cme250 to work properly. either
The problem could be a series of things beginning with ambient temperatures
too high, fan not working properly, if water cooled there could be a problem
with that also. As a technician I would first look over the condenser and make
sure air flow is proper and then attach my gauges to see the suction and
discharge pressures. I have found many restaurants that keep their ice machines
in the hot kitchen where it creates high ambient temperatures and allows grease
from the grill to collect on the condenser blocking air flow. Yes under charged
is possible or over charged but the best and most effective route is to call a Scotsman
Certified Technician. I have worked on Scotsman's and they are very tricky to
fix unless you know the process of event. If water is not pre-filtered there is
a chance that the water control valve may be stuck open allowing warm water to continue
flowing causing these symptoms. Here Is a=> Scotsman
CME250 Ice Machine User Manual If
unable to find these simple checks above or from the manual and still having
problems it will need to be time to call a Technician. If you do not have Adobe
Reader Click Here=> Adobe Reader X (10.1.0) Tell
me what you find and please don't rate me if I was unable to solve this from
here. I am here to help you up and to the point of calling Scotsman for addition
help. Thanks,
Sea Breeze
I have a I have a Scotsman SCCP30MA that stopped dropping ice . I have unit defrosted and cleaned. What can I do to check that things are functioning as they should? Please help. Thanks.
To check if the ice maker in your Scotsman SCCP30MA is functioning properly, you can try the following steps:
- Ensure that the ice maker's water supply is turned on and that the water line is not clogged or frozen.
- Check the thermostat settings to ensure that the freezer is at the proper temperature.
- Inspect the water inlet valve to make sure it is not clogged or defective.
- Check the ice maker's control arm to make sure it is in the correct position and not blocked.
- Inspect the ice maker's ejector blades to ensure they are not clogged or damaged.
- If the above steps do not resolve the issue, the problem may be with the ice maker's control module or motor, which would require professional repair or replacement.
It's also important to check your machine's manual, as it may have additional troubleshooting steps specific to your model.
1/22/2023 6:07:06 PM •
Scotsman...
Answered
on Jan 22, 2023
Hi my scotsman mv 450 only makes 150kg in 24 hour cycle and not 215kg
how old is it? when was the last time u had pm done?
have a qualified hvac/refrig tec come do a pm and you will know.
they will check voltages/amperages, pressures, valves timers etc.
trust me, this is your only answer (unless you have it in a location that encloses it in a 100 degree room without ventilation.
get proper pm service done.
1/3/2015 3:16:24 AM •
Scotsman...
Answered
on Jan 03, 2015
Can t get scotsman cme1656rs to start
problem was not the universal controller. The bin sensors are dirty and scaled up and gives the same indication that bin is full. find the sensors and clean the scale off and unit should start working again. Save the card, you will sooner or later probablly need it.
10/1/2014 12:46:52 AM •
Scotsman...
Answered
on Oct 01, 2014
Water diagnostic code
I do not have enough of your water diagnostic code, but the normal cause is the dual temperatur probe, if the sensor that is inserted just downstream of the water pump is bad and doesnot sense the temperature change as the water cools the unit senses this as a water pump problem and stops the freeze cycle but shutting down and giving a water code. PS I use to know a guy on the USS George Bancroft before 1980 named DJ White. If you were this guy I still have your ship's plaque if you want it.
Joe Abbey
10/1/2014 12:21:31 AM •
Scotsman...
Answered
on Oct 01, 2014
Bin full light
The sensor build limestone residue during operation and needs to be cleaned off. The bin sensors are typically located on either side of the freeze platens and can be removed to clean. Turn machine off and unplug. Reach in past the water trough and freeze platen and you will see the transmiter and receiver plugged into the side walls. Gentlely work sensor loose and work sensor wiring out hole until you can get to sensors. Clean the two sensor with a clean cloth and with vinegar until sensers are clean. Reinstall, and plug back in and start unit. Bin sensor light should be out and should start.
10/1/2014 12:10:18 AM •
Scotsman...
Answered
on Oct 01, 2014
My Scotsman 275 is giving me a refrigeration error
If the water pump is not working, or working intermittenly, it is the first thing I would replace. Often causes for water pump failure is bearing/bushing failure and excessive limeston buildup. As for as the refrigeration error, there is a dual probe sensor that inputs temperature into the control card for the discharge temperature of the compressor and the water pump discharge temperature. You can check to see if each of these device are function with a ohmmeter and see if the resistance is 10k - 15k ohms. If either of these do not check out, it needs replaced. Next see if the condenser is dirty, excessive freeze times can cause refrigeration error due to excessively long freeze time (freeze times >60 minutes). If dirty, clean coil until you can see light through the coils. During the operation, check to see if the fan runs continously during freeze cycle. If it starts and stops or just stops, fan motor needs replaced. Any thing more will require an ice machine tech to troubleshoot with his instruments. Hope this helps a little.
10/1/2014 12:01:49 AM •
Scotsman...
Answered
on Oct 01, 2014
