1. Please try to use a different Monitor just to check if you still see the white screen.
2. If you still see the white screen on a different monitor, then your video card is affected.
3. But if you don't see the white screen using a different Monitor then, I would say that your monitor is defective, now if your monitor still under the warranty, I would suggest to get in touch with your manufacturer so that they can fix or replace your monitor.
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
Please record the amount of time that it takes until your device goes into sleep mode and set a timer for 5 minutes less than that time everytime you begin to use the lg device. At the points the timer/alarm goes off, you can simply lower/increase the volume and the lg's internal sleep timer should be reset.
Thank you.
Please try using an alternative connection to the hdmit and test the monitor buttons again. And using analog mode prior to testing the monitor buttons again sounds like a good test as well.
Thank you.
'the nozzles orange'? Do you means 'orange nozzles', or is 'orange' a typo? There should be no oranges back there :>)
It you have removed the dispenser drawer, the nozzles cause the water to flow into the correct compartments.
You can check parts diagrams to identify any part. Please always include FULL make and MODEL in all questions.
https://www.google.com/search?q=lg+washing+machine+parts+diagram
