Hi
Please check the water inlet valve, it might be frozen or blocked
with mineral deposit. Use a hair dryer to remove the blockage. Make sure the
water inlet valve's screen is not blocked. If the issue persists, then the
water inlet valve has gone bad, use a multimeter to test the water inlet
valve's continuity. Use a multimeter to test the continuity. If that is fine then test the auger motor and replace if bad. Hope this
helps...please post back for further assistance.
Daniel
1 questions posted
7 Questions
