20 Most Recent
toshibadirect.com Questions & Answers
I have a Toshiba HDDR500E03X external hard drive,
Your hard drive is probably dead. However there are stillhopes for
hard drive datarecovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezingsometimes works to revive a dying hard drive, at least for a shorttime(Probable just about 20 minutes), but be sure that the bag is sealedtightly so that condensation and ice crystals don't form. Put it in yourfreezer for 24 hours that will do the trick. While it's still cold, plug itinto your computer.And you may be able to view it in 'my computer'. And you mayact quickly,because you may only have 20 minutes to recover your data off itand after that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply datarecovery service but let's hope not because it will cost you a lot of money andwhether they can recover data is not guaranteed.
Here is a tutorial to guide you
how torecover data from hard drive.
For some reason I can no longer copy from my VHS
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Forgoten password
Password Protection On Laptop Computers.
Are Security features, So that Only The Owner or Purchaser of That Specific laptop.
Can be Used By That Person (s)
Contact Toshiba for Help-Service.
Not many Fixya Experts, will help anyone to Unlock or Remove A Password.
This Is to Restrict, Purchasers of Stolen electronic equipment.
Mike.
Printing from a computer, get paper jam, clear it,
You can work this around by using a little manual labor. Whenever the paper jams and doesnt continue from previous page, you can unplug the printer from the electricity. (not just the on/off button).
This way it loses the document that was printing from the memory.
Then you can send the doc for printing again by designating which pages to print.
ex. if your document was stopped at the 12 pg and it has 20 pages.. go to print> and then choose which pages to print i.e. 13-20.
I hope this helps.
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
2 days ago
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
