20 Most Recent Panasonic Lumix DMC FZ35 Digital Cameras Questions & Answers
New Dell, running Windows 7 professional. Photofunstudo 4.0 will not run. Error message: not compatible with OP. Can U help?
Some software will only run on a 32-bit OS - can you check to see if there is a 64-bit version of Photofunstudio available ? Good luck.
12/27/2015 1:03:25 PM • Panasonic Lumix... • Answered on Dec 27, 2015
What does "NOW WRITING" mean on my digital camera screen when I try to record videos?
This means that the video file is being saved on your camera's internal storage.
7/19/2013 8:30:09 PM • Panasonic Lumix... • Answered on Jul 19, 2013
2answers
On/Off Switch Doesn't work on Lumix DMC-FZ35
Unless you have the knowledge to dismantle and fix it, you need the services of a repairer. Sorry.
7/8/2013 4:51:15 AM • Panasonic Lumix... • Answered on Jul 08, 2013
2answers
Lock Memory card
Think the memory card has a write protection switch. Eject memory card and flip switch.
1/13/2013 1:59:42 PM • Panasonic Lumix... • Answered on Jan 13, 2013
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
10/27/2012 4:13:41 AM • Panasonic Lumix... • Answered on Oct 27, 2012
Built-in memory error
is it charged?try using it whilst its plugged in
8/16/2012 3:22:37 PM • Panasonic Lumix... • Answered on Aug 16, 2012
Panasonic FZ35 zoom error
Please remove the battery and then restart your phone , once done, check if the error persist.
6/29/2012 6:31:50 PM • Panasonic Lumix... • Answered on Jun 29, 2012
2answers
I have a panasonic Lumix camera and it keeps
Hello and Welcome to FixYa!
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
You can see the snap attached below;
If the lock switch is not on lock;
  • Slide the switch up and down. Repeat this 3 times.
  • Let it stay on the Lock position for 30 seconds.
  • Slide the switch up to unlock the card.
  • Try to transfer files into the device.
If none of the above works, then you card in either damaged (Format it) or is Password protected.
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
11/28/2023 7:18:52 PM • Panasonic... • Answered on Nov 28, 2023
2answers
How to change language for Panasonic tz110 camera
https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English/TZ80_and_TZ110_Basic_Operating_Instructions.pdf
3/28/2023 1:59:38 PM • Panasonic... • Answered on Mar 28, 2023
I want to change language from Japanese to English Panasonic CN H500D
To change the language on your Panasonic CN-H500D, press the "Menu" button on the remote control. Use the arrow keys to select the "Setup" option, then press the "Enter" button. Select the "Language" option, then press the "Enter" button. Use the arrow keys to select the language you want to use, then press the "Enter" button. The language will now be changed to the one you selected.
2/21/2023 10:01:11 PM • Panasonic... • Answered on Feb 21, 2023
2answers
My panasonic vdr150 pc mode not working
It sounds like you are having trouble using your Panasonic VDR-D150 camera in PC mode. Here are a few things you can try to troubleshoot the issue:
Make sure that the camera is properly connected to your computer via the USB cable.
Check that the camera is turned on and in PC mode.
Check that your computer recognizes the camera as a device. You can do this by going to the "Device Manager" in the Control Panel and seeing if the camera is listed under "Imaging devices."
If the camera is not listed in the Device Manager, try unplugging and re-plugging the USB cable and restarting your computer.
If the camera is still not recognized by your computer, try using a different USB cable or a different USB port on your computer.
If none of these steps help, it is possible that there is a problem with the camera itself. In this case, you may need to contact Panasonic for further assistance.
12/24/2022 10:12:47 PM • Panasonic... • Answered on Dec 24, 2022
I need charger for Panasonic ER2031K model beard hair trimmer
We do not sell anything here, try eBay.
11/22/2022 4:59:51 PM • Panasonic... • Answered on Nov 22, 2022
My Lumix dmc fz4 turns on and says memory card
Camera only supports Standard SD cards up to 2GB. I would go from there.
9/30/2022 12:11:49 AM • Panasonic... • Answered on Sep 30, 2022
Panasonic Lumix DMC FZ35 Digital Cameras Logo
13 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Panasonic Cameras
  • Panasonic Cameras
Most Popular Question
lumix dmc fz35 lens opens retracts
  • Cameras
