20 Most Recent Garmin Nuvi 660 4.4 in. Car GPS Receiver Questions & Answers
Caw we pair 2 cell phones with different call numbers with our car gps?
nuvi 660 does not support mutiple phones pairing simultaneously over blue tooth. However you can drop the old and add a new Garmin Zumo 660 User Manual Changing The Proximity Points Settings
4/27/2016 3:36:43 PM • Garmin Nuvi 660... • Answered on Apr 27, 2016
Where can I get a replacement ribbon (printed circuit) connecting the arial to the main body?
Please email us at SHARCNET-USA AT SHARC DOT NET. FOR INFORMATION ON OBTAINING A REPLACEMENT FLEX CABLE
3/24/2016 11:50:43 AM • Garmin Nuvi 660... • Answered on Mar 24, 2016
2answers
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
11/30/2022 6:56:43 AM • Garmin nuvi GPS • Answered on Nov 30, 2022
2answers
My garmin nuvi says system sofeware missing
Download Garmin Express from Garmin and install to your PC. Plug your GPS into your PC, Garmin Express should identify your GPS and give you options to update maps and software.
10/6/2022 8:21:22 AM • Garmin nuvi GPS • Answered on Oct 06, 2022
2answers
How do I turn on my Garmin Nuvi?
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged. It is quite possible that your battery is discharged. You might leave it plugged into your PC overnight if the battery is dead.
9/20/2022 7:54:45 AM • Garmin nuvi GPS • Answered on Sep 20, 2022
How do I bypass a pen lock screen on a Garmin nuvi 1450
Go onto the Garmin web site and reset the 1450.
10/14/2021 6:42:57 AM • Garmin nuvi GPS • Answered on Oct 14, 2021
How do I fix the backlight of my garmin 3205
The LCD display contains both the display and backlight. They are integrated as one piece. Therefore the entire display needs to be replaced. The backlight connections are soldered to the LCD connections. Replace the entire display.
5/2/2021 8:28:01 PM • Garmin nuvi GPS • Answered on May 02, 2021
I have a Garmin Nuvi 850. Unit battery doesn't charge up in car
Broken wire in the lead or a faulty plug at one of the ends. replacement https://www.ebay.ca/itm/Garmin-GTM21-USA-Can-Lifetime-Traffic-Cable-For-Nuvi-6xx-680-750-760-780-850-855/333914865288?hash=item4dbee07e88:g:EvgAAOxyMxpRrY3t
garmin nuvi cable traffic ' eBay
https://www.ebay.ca > sch
Find great deals on eBay for garmin nuvi cable traffic. Shop with ... Garmin GTM21 USA/Can Lifetime Traffic Cable For Nuvi 6xx 680 750 760 780 850. Sponsore ...
4/16/2021 4:25:32 AM • Garmin nuvi GPS • Answered on Apr 16, 2021
Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help Number
When encountering errors such as "No Map Data Available" and Garmin Express does not recognize your Garmin nuvi, check to see if your Garmin nuvi is out of storage space from your computer. Solution related to the fact that when brought up as the E: drive in windows there were 0 bytes free space on the Garmin nuvi. To get Garmin Express to recognize a unit which is full, do a search on the Windows Drive (E:) for "gmap" then choose "Open file location" This will get into the hidden ".system" directory. From there, delete the largest file map, such as "gmapprom" (or move this file to your hard drive). Afterward, reboot your computer to have Garmin Express software recognize your Garmin nuvi. On older units, also purchase a microSDHC card to be able to store the newest maps, such as the US & Canada 2.6Gb map file, which will not fit on the internal unit alone or a 2Gb card. The Garmin Express software will recognize 4Gb to 32Gb microSDHC Class 10 or UHS-I cards formatted to FAT32 and install the newest maps automatically to them. Some have reported that 4Gb cards are not large enough. I had used a 16Gb SanDisk Ultra PLUS UHS-I card ($10.88 Walmart) successfully on my Garmin nuvi 1450LMT
11/17/2019 7:22:01 PM • Garmin nuvi GPS • Answered on Nov 17, 2019
My garmin nuvi 2225 will not acquire satellites since I brought it to Europe. I loadd maps for the area but it can not find its position.
If the garmin can reach satellites in North America, it will reach satellites anywhere in the world as long as it has a clear line of site to the satellites. Depending where you are, the satellites can be higher or lower in the sky. This means that the garmin in your vehicle may not be able to see the satellites how you have it positioned in your vehicle. Try finding the satellites outside of your vehicle while in Europe. If you can, then the problem is positioning in your vehicle. The satellites are all the same kind no matter where you are.
11/13/2019 5:16:19 AM • Garmin nuvi GPS • Answered on Nov 13, 2019
Garmin nuvi 2225 will not acquire satellites in Europe. Worked fine in North America. I loaded maps for Europe but no action.
11/13/2019 5:15:54 AM • Garmin nuvi GPS • Answered on Nov 13, 2019
I just downloaded the new software on my nuvi 260w i dont know if i get the traffic also.
Contact Gamin support on this.
12/14/2018 11:13:47 PM • Garmin nuvi GPS • Answered on Dec 14, 2018
Garmin Nuvi 660 4.4 in. Car GPS Receiver Logo
2 questions posted
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
caw pair 2 cell phones different call
  • GPS
