20 Most Recent Humax DRT400 DVD Recorder w/ 40 hr Tivo Questions & Answers
2answers
My Humax Duovisio PVR-9200T often freezes
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
7/8/2010 6:33:39 PM • Humax DRT400 DVD... • Answered on Jul 08, 2010
Picture stays frozen on Powering Up
It may be that the Tivo has gone south. One option would be to send the Tivo in for service. Often times, the first thing to fail is the hard drive which could be causing your problem. To fix this, you could either purchase an upgrade kit with the Tivo software preloaded or purchase a new drive and configure and install the software yourself. Your service subscription is tied to the box id, not the hard drive.
You can find out more inforamtion on www.tivocommunity.com or look specifically for the hinsdale howto which talks about upgrading the tivo. If this is the problem, the advantage is that you may come out with a Tivo with more storage. If the hard drive is not the problem, this will be of no use.
6/2/2009 8:48:01 PM • Humax DRT400 DVD... • Answered on Jun 02, 2009
I cannot turn the subtitles off on recorded programs
Try Turning Subtitle Option Off Before Recoding.
4/7/2009 6:20:53 PM • Humax DRT400 DVD... • Answered on Apr 07, 2009
Celcus LED28272HD what is the tv code for humax remote control
You did not mention model of remote control. You can download the required manual for your remote control from following link. Remote Control Code List ' HUMAX-United Kingdom (humaxdigital.com)
12/31/2023 11:58:05 AM • Humax Televison... • Answered on Dec 31, 2023
Humax 5000t does not find HD channels when scanning
If your Humax 5000t is not finding HD channels during scanning, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can try:
  1. Check signal strength: HD channels may require a stronger signal compared to standard-definition channels. Make sure your antenna or cable connection is secure and properly aligned. You can also try repositioning the antenna or cable to improve the signal strength.
  2. Perform a full rescan: Sometimes, a full rescan can help resolve channel detection issues. Go to the settings or menu of your Humax 5000t and find the option to perform a full rescan or channel search. This process may take some time, so be patient and allow it to complete.
  3. Update the firmware: Outdated firmware can cause compatibility issues and affect channel scanning. Check if there is a firmware update available for your Humax 5000t. Refer to the manufacturer's website or user manual for instructions on how to update the firmware. Follow the recommended steps carefully to avoid any potential issues.
  4. Verify broadcast standards: Ensure that your Humax 5000t is compatible with the broadcast standards used in your region. Different countries and regions may use different broadcast standards for HD channels. Check the specifications of your Humax device and confirm that it supports the specific HD broadcast standard used in your area.
  5. Reset to factory settings: As a last resort, you can try resetting your Humax 5000t to factory settings. Keep in mind that this will erase all your saved settings and recordings, so make sure to back up any important data beforehand. Look for the reset option in the settings menu of your device and follow the on-screen instructions.
If none of these steps resolve the issue, it's advisable to contact Humax customer support for further assistance. They can provide specific troubleshooting guidance based on your model and help you resolve the problem with HD channel detection.
7/14/2023 6:07:31 PM • Humax Televison... • Answered on Jul 14, 2023
Humax FVP-5000T Freeview Play Recorder. I cannot connect FVP-5000T to the internet. LAN is working plus all other internet devices.
Question edited for a lot more clarity. Question moved to Humax category. " I have tried all suggestions in your manual " Not OUR manual, we are Fixya dot com, we are nothing to do with Humax, we are not who you think we are. First, fully disconnect all devices from mains power for 15 minutes, router, television and the Humax Box. Plug in the router first, then the Humax and finally the television. It will take about 15 minutes for them all to come back online after the reset and all recognise each other. This is called a 'Power Cycle' and reloads all the software and connections. Then try again. If that doesn't fix it, you can fully Factory Reset the Humax unit, or you can just go into Settings and put the router settings back in SSID and Password. https://www.google.com/search?q=humax+fvp-5000t+reset ..
6/11/2023 4:32:31 PM • Humax Televison... • Answered on Jun 11, 2023
It reads: The file cannot be changed
It's possible that there may be a software issue with your TV or Humax box that's causing this problem. Here are a few troubleshooting steps you can try: Update the firmware: Check if there is any firmware update available for your TV or Humax box, and if there is, install it. This can often fix any bugs or issues that may be causing the problem. Check the file format: Make sure that the recorded programs are in a supported file format. Some TVs and media players may not support certain file formats, which can cause playback issues. Reset the TV or Humax box: Try resetting the TV or Humax box to its default settings. This can sometimes resolve any software issues that may be causing the problem. Contact support: If the issue persists, you may need to contact the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or suggest a repair or replacement if necessary.
2/24/2023 2:28:38 PM • Humax Televison... • Answered on Feb 24, 2023
I need to know how to operate and set up a Humax TV set-top box recorder.
Question edited for clarity, 'humex' to 'Humax'. Question moved from Cars and Trucks category. They make a few models, but here an instruction manual. They can all be found using Google 'make MODEL manual'. https://manuals.plus/m/0138caa99174c297359582f8a646f28b2f701887be87631db85aed03fd9d43a6 ..
7/11/2022 3:18:19 PM • Humax Televison... • Answered on Jul 11, 2022
2answers
Remote for Humax recorder is not working. Can I get a new one?
you can order on line
1/17/2022 8:47:44 PM • Humax Televison... • Answered on Jan 17, 2022
Humax PVR-9300T It's screen shows fault code 576p a few seconds after switch on. Can you help
Sorry, not familiar with this brand
12/5/2021 3:07:08 AM • Humax Televison... • Answered on Dec 05, 2021
I need factory code for humax tv
Model? have you tried ebay?
8/19/2021 7:46:56 PM • Humax Televison... • Answered on Aug 19, 2021
I have today bought a Humax HDR-1800T Freeview Recorder. I have been trying to connect it with my TV but a message either no signal or weak signal keeps recurring.
sadly you need to contact the seller with this one . we do not know what you are hooking it to for input
4/16/2021 4:08:32 PM • Humax Televison... • Answered on Apr 16, 2021
I have a Humax HDR-2000T when I select TV Guide not all the programmes are displayed however, all the channels are present.
you would have to ask that of the station producers
11/20/2020 4:18:47 PM • Humax Televison... • Answered on Nov 20, 2020
My Humax Freesat box has recently stopped playing utube.How can I get it to play again?
What actions preceded the breakdown?
10/19/2020 8:59:38 AM • Humax Televison... • Answered on Oct 19, 2020
Televison & Video Logo
8 questions posted
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Humax Televison & Video
Most Popular Question
humax duovisio pvr 9200t often freezes
  • Televison & Video
